Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Smoking
My car has always smoked just a little when im on it at full throttle, but lately its been smoking heavily full throttle or not , sometimes even at idle. It also does it horribly throughout second gear. Its always white never black. Any thoughts or ideas?
1990 LX hatch
pcv, or worn rings mabe a good scratch in a cylinder. bad valve guide, it could be alot of things.
2003 SVT Cobra
11.70 @ 121
what about the head gaskets? could that be a problem? i was thinking about replacing them today....
1990 LX hatch
It's really hard to say, are you loseing coolant, oil or both? usually you wont burn oil with a blown out head gasket.
if its a head gasket, like he said, you should be loosing coolant.....also the smoke might look like it has a blueish color and actually smells kinda sweet.
Blue smoke = oil, white smoke = coolant.
2003 SVT Cobra
11.70 @ 121
i havent lost a drop of coolant... i need to do something though because i dont like to ride around in a car blowing smoke everywhere...
#8 | |
It may be worth psyching up to do the headgaskets and as you pull everything apart, thoroughly examine all the gaskets and connections. It could be a bad gasket other than the head gaskets and if it is, you'll find it on your way to the headgaskets. |
agreed could be a number of things. process of elimination bro.
2003 SVT Cobra
11.70 @ 121
the only thing is , i am no mechanic , i dont really know enough about cars to be pulling my motor apart , if i were going to change the gaskets i was going to take it to a local shop and get them to do it
#11 | |
Get you a Haynes or Chiltons and go at it...Top end is a piece of cake man...Get you some scotch tape, and a marker, label things as you pull them, maybe take pictures if you need to.
Just a thought.. Pull the valve covers off, look at the valve guide seals (underneath the springs) If for whatever reason they've lifted off the guides, or are torn/stretched/etc, this combined with guides/valves that are wearing out (but are not yet an issue) could cause oil to get into the combustion chamber...
I've seen a really bad case where so much oil got into the combustion chamer that the pistons had a layer of oil baked onto them, and the valves were so caked it had to have hurt performance.. by a lot |
#14 | |
#15 | ||
and 1) Mine blew smoke that looked very white, but it was definitely oil. |
Well for sure he prob aint gonna pinpoint it himself. But over the years I have become a very strong believer of the use of a leak down tester. It is an invaluable tool. Compression tests dont tell you shit and are a waste of time..
Threads Similar to: Smoking
| 97 Cobra, is now Smoking! | acobraman | 96-98 | 3 | October 28th, 2007 12:14 AM |
| The car is smoking??? | auburntiger7231 | 99-04 | 20 | October 15th, 2007 05:04 PM |
| Won't see this on the telle: smoking a joint | WAR-PARTY | The Clubhouse | 6 | July 11th, 2007 06:41 PM |
| Smoking After Idle | Dennis | 96-98 | 4 | December 10th, 2006 10:36 PM |
| Smoking On Takeoff | dbeller | 96-98 | 2 | October 3rd, 2006 08:23 PM |
