starter stuck on!
Old July 2nd, 2010, 12:33 AM   #1
adrce55 is on a distinguished road
starter stuck on!
im having a problem with my 92 gt.
observations
1. when i go to turn the ignition key, the starter is already starting to engage in position 2. i havent even turned the key all the way and the starter is already turning.
2. once the car is running, you can definitely heard something spinning, probably the starter.
i already changed the starter thinking the solenoid on the starter was jacked, but that didnt help.
any thoughts?
thanks in advance
1992 Mustang GT
Old July 2nd, 2010, 12:53 AM   #2
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
Sounds like the ignition switch is bad
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Old July 2nd, 2010, 11:43 PM   #3
Serpent's Avatar
86 GT 5.0
Serpent is on a distinguished road
I had the same thing happen went through 3 starters and solenoids and replaced the ignition and ignition box. The only starter that would work is a brand new one. The refurbished were doing the same thing for some reason. Did you use a new starter or a refurb?
This is a weird little gremlin to chase out.
Old July 5th, 2010, 02:17 PM   #4
im bought a refurb'd starter...
i just changed the fender wall solenoid (heavy duty) and ignition switch...and it is still stuck on!
1992 Mustang GT
Old July 5th, 2010, 07:16 PM   #5
Serpent's Avatar
86 GT 5.0
I am in the same situation. Mine was good for a week then it happened again. I see this all over the different mustang forums. I have yet to hear a solution. I am going to try to shim out my starter to see if that helps. I dont know what else to do. I did notice 1 tooth missing on my flywheel. This is the olny other thing that I think it could be. But with the frequency I see this happening I am thinking it is something else. Electrical is my guess.
I have replaced my entire starting system and it is still doing it.
Threads Similar to: starter stuck on!
Starter solenoid clicks at the starter but wont start the car?? 95StangSVT 94-95 13 March 11th, 2010 10:22 PM
Im stuck on this one nightrunner 5.0 Mustangs 4 April 25th, 2009 07:27 PM
stuck again SWEET2KSTANG 99-04 30 December 11th, 2008 05:31 AM
I'm stuck. Dansby The Clubhouse 13 March 2nd, 2008 09:18 PM
Starter or Starter Relay cobralini 5.0 Mustangs 7 August 3rd, 2006 06:34 PM
