91 lx convertible
stock 5.0 what simple modds to start with
got a 91 lx convertible aod tranny with 90000 miles i am the 3rd owner... What would be the best starting bolts ons. I am new to the 5.0 thanks in advance and the car is bone stock
1992 Mustang LX
13.0 @ 105
well 4.10 gears are a great place to start. An h-pipe is also good to add being that the stock catted exhaust is very restrictive. Not much performance in mufflers really, but you'll get that sound that you want.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
1989 Black LX---Turbo
A couple free-be mods to do are set your timing to 12 degrees advance and remove the air silencer thats in the inner fender right behind the air box. Next I would say gears would make a big difference, and a stall converter makes a big difference in an AOD car.
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
Priest of the Car Gods
Subframe connectors are the very first thing I'd do (and did, with mine). Foxes are pretty flexy, and with the roof cut off it only gets worse.
I'm not convinced pulling the air silencer actually gets you any gains, it's not restrictive at all, and allows the airbox to pull cold air from inside the fender rather than warm air from inside the engine bay. Are you planning on keeping the auto or swapping to a stick? If you're keeping the automatic, I'd get a deeper tranny pan plumn in an aftermarket tranny cooler.
#5 | |
1990 LX hatch
Yeah, it's the rubber snorkel that attaches to the bottom/side of the air box and goes into the fender, right? That's what I've always called the silencer.
1990 LX hatch
http://image.musclemustangfastfords...._upgrades+.jpg
IDK, its the thing on the left. THe opening on the air box, is larger than the opening on the silencer, and they pull air from the same place, as long as the airbox is still in place.
1990 LX hatch
THere is a 100 cfm difference
100 cfm difference? According to what? And what are the two numbers? If we're talking 1100 vs 1000 cfm, 100's not very relevant, especially when you consider that the stock heads aren't gonna flow anywhere near there.
EDIT: Huh... according to the myth destroying sticky, you're absolutely right: ![]() Reps to you, man.
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Last edited by ReverendDexter; July 4th, 2010 at 12:32 PM. |
1990 LX hatch
447 to 551, thru the box and intake tube.
Well, I know one little air silencer that's getting yanked when I get home from work.
1990 LX hatch
lol I thought I was right, I havent taken one off in over a decade, and I was starting to second guess my memory...
1990 LX hatch
If I remember right its a PITB. I think you can get it out with out taking the fender liner out tho.
My passenger side fender liner was gone when I got the car, so no biggie there.
91 lx convertible
one question thiss car is also my daily driver. So what gears would save more gas the 4.10 or the 3.73?
1990 LX Coupe
#17 | |
If you want more info, do a search. There's probably 100 threads on "3.73s vs 4.10s", and there's not a definitive answer.
subframe connectors should be your first mod.. even a stock powered vert can and will twist the frame. You'll feel a difference in the ride and stiffness after the subframe install.
95 Mustang GT
Yeah definately I would get subframes on that car before you twist it up. Especially since its a vert. Bad enough with a hard top.
![]() People should think about boarding up their glass house before starting a rock fight! |
1988 Mustang 5.0 LX
12.48@118.27
I wish I did subframes first
Threads Similar to: stock 5.0 what simple modds to start with
| modds | skid6 | 5.0 Mustangs | 22 | July 10th, 2007 12:56 AM |
| Starting Modds | atticus1111 | V6 Mustangs | 27 | June 6th, 2007 10:20 PM |
| Visual Modds | Onemanzu | V6 Mustangs | 4 | November 3rd, 2006 06:34 PM |
| I Need More Modds! | jerb43 | 96-98 | 12 | November 2nd, 2006 04:52 PM |
