1988 mustang lx
gear install
OK so after figuring out my 8.8 rear only had 2.73s in it I've decided to put gears in.now will I be good with just the ring and pinion set and a bearing/seal kit with the crush washer or do I need clutch packs..etc
Also what would be my best bet for gears, 3.73 or 4.10..the car is not my daily driver and only sees the road 2 to 3 days a week
![]() lock it up?!
1992 Mustang LX
13.0 @ 105
stick or an auto, i think i would go with 4.10's... i have 3.73's in mine and i think i should have gone with 4.10's because from what i hear it will knock a tenth or two off comparitively...and ring/pinion is all you need really. the bearing seal kit is good too...how many miles are on the rear? is your posi wearing out? maybe you'll need clutch packs.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
1992 Lx
11.39@119.24
If youre gona keep modding the car ie making more power at higher rpms, 4.10s
1988 mustang lx
Its stick and I believe the posi is still original so I might have to get a clutch pack
![]() lock it up?!
do a burn out.. if your only burning one wheel then you'll need to rebuild your trac lok, if not then don't worry about the clutch packs right now unless you have the money to spend.
3.73 gears are the best gear for a full weight fox.. sure everyone says 4.10's but unless you have a top end setup on the car you'll be running outta rpms in the 1/4 mile, at least I did and I didn't really like cruising with it neither. |
flyin ryan is right, but also at the same time, its what 80 bucks from ford for a rebuild kit, and you already have it out, doesnt hurt to do it all at once while you are in there so you dont have to drain and refill, remove the axles, and all that jazz again when/if you do it later
1988 mustang lx
well its a stock top end but it does have a cam and exahust, and i'll be getting a new upper/lower intake eventually, still go with the 3.73s?
![]() lock it up?!
Threads Similar to: gear install
| Gear Install | 6DXR | The Clubhouse | 8 | January 26th, 2010 01:44 PM |
| Gear Install? | stang_soldier | 99-04 | 8 | August 27th, 2009 11:53 AM |
| 3:90 gear install,:( | spike spiegel | 99-04 | 27 | September 20th, 2008 04:46 PM |
| Is this right? Gear install | mikevm78 | 99-04 | 17 | February 4th, 2008 10:14 PM |
| Gear Install | acehogg69 | 2005 - 2010 | 7 | January 28th, 2007 12:49 PM |
