batter meter jumpine around
Old July 6th, 2010, 01:15 PM   #1
navy-ad3 is on a distinguished road
i got a 94 mustang gt. the battery meter jumps around the alternator is newer but the battery is a cheap pep boys special i cant figure it out lol hopefully someone know what the problem is i really appriciate the help thanks
Old July 6th, 2010, 02:12 PM   #2
nolife's Avatar
91GT, 88GT, 02GT
Usually means the battery is weak or old or the battery terminals and wires are corroded.
With a good battery, wires and a good charging system, the difference between the alt output and the battery voltage should only be 1 or so volts which will cause small fluctuations. As the battery gets weak or the terminals get dirty, the voltage difference is larger and the "voltage" fluctuations get larger. Try sitting at idle and turn the 4ways on, see if it is jumping with the lights.
In general, there is nothing wrong with a Pep boys or a cheap Walmart battery. Batteries are wear items, you may just need a new one or your terminals and wires checked.
Threads Similar to: batter meter jumpine around
Where can I find a dwell meter/tach meter helpmeplease321 Classic Mustangs 3 August 13th, 2008 12:22 PM
Where can I find a dwell meter/tach meter helpmeplease321 General Tech 0 August 12th, 2008 07:33 AM
Batter light AnFking6908 V6 Mustangs 1 April 11th, 2008 11:47 PM
meter patwrecked 5.0 Mustangs 32 September 27th, 2007 12:26 AM
mileage meter new 5.0 5.0 Mustangs 1 December 20th, 2006 09:38 AM
