The best computer managment
Old July 7th, 2010, 01:30 AM   #1
SCREAMPUFF87GT is on a distinguished road
I would really like anyone's suggestions on the best computer chips and hand held programmers. Its for a 87 gt 5.0 with free-flow exhaust and upgraded injection with spacer and bigger throttle body fan delete and ac delete along with smog pump.-------
O
O
O
Old July 7th, 2010, 01:31 AM   #2
Thanks Guys
Old July 7th, 2010, 01:34 AM   #3
91sleeper's Avatar
1991 notch
91sleeper will become famous soon enough91sleeper will become famous soon enough
explain and chances are you will not need a tune. And there is not hand held for our cars. Also have you converted your car to mass air?
It can't be that fast cause it still has the stock hood.
-some punk
Originally Posted by flyin ryan View Post
8 sec 1/4 times are soo 2009. Im running 6 sec slips in my dd 302 pig with street tires
Originally Posted by flattusmaximus78 View Post
Nah not even stock form. I just made it up.
Old July 7th, 2010, 01:39 AM   #4
I just got the car and started with it Just upgrade the mass flo?
Old July 7th, 2010, 01:46 AM   #5
Any other ideas? Anybody?
Old July 7th, 2010, 10:19 AM   #6
fogged306's Avatar
89 GT
There's a lot of different routes to go. You can do a TwEECer or a Moates Quarterhorse which are very similar. They require a laptop and are actually able to change parameters in the EEC. They have a bit of a steep learning curve but are very capable. There's also the Anderson PMS which has a handheld control unit and that piggybacks on to your computer and "fudges" data going in and coming out. They are easier to use but also aren't as capable as the other 2. You could also go with a stand alone system like a megasquirt or an AEM or FAST ect.. .but if you're just playing around with your car and not serious about racing, those are probably overkill. I'm sure there's a few more units that I've missed, but your best bet is to check out stangtuning.net and do a little research and see what would suit you best.
Old July 7th, 2010, 10:41 AM   #7
Authorized Vendor
Matt Cramer's Avatar
Matt Cramer is on a distinguished road
There is no one best, only best for what you need. For example, if you're building some sort of screaming 8,000 RPM monster with eight EGT probes, crank triggered, with eight separate coils for the ignition, AEM has a box that would be perfect for that motor. On a car like yours, you'd probably be throwing your money away.
We've recently come out with a plug and play MegaSquirt-II setup for $560 that does not require converting to mass air flow. It is aimed more at heavily modified NA cars or turbo motors than a mildly modified engine, but can get results there too if tuned properly.
There's a couple different ways to hack the stock ECU too, like the Moates Quarterhorse.
Keep in mind that any tuning solution that lets you tune the ECU yourself is going to take quite a bit of time on a dyno to get the most out of it. If you don't know how to tune, or don't have a good way to measure if the changes you're making are actually improving things, you may just end up with enough rope to hang yourself.
Old July 7th, 2010, 11:04 AM   #8
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
I bought the Moates Quarter Horse over the Tweecer for one reason. The Quarter Horse software is far superior. Either way you are going to need a wideband, so you can monitor your air/fuel ratio. Or else your just shooting in the dark! I would recommond the Innovate LC1. Can be had off of Ebay for around $180. Good luck in your quest.
You probably won't need a tuner until you are heavily modified anyway!
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Old July 7th, 2010, 11:14 AM   #9
91sleeper's Avatar
1991 notch
moates is what I use
-some punk
Threads Similar to: The best computer managment
Nitrous Managment Unit Not Working?! '97'Cobra Modular Mustangs 3 October 20th, 2009 02:30 PM
Need computer help. Dansby The Clubhouse 21 March 3rd, 2009 10:55 AM
Computer help... NOW! Onemanzu The Clubhouse 21 January 26th, 2009 04:10 PM
Fuel Managment sniperrider 5.0 Mustangs 25 March 28th, 2008 10:19 PM
Is An 93 5 Speed Computer The Same As An 89 A9l Computer?? e3sean 5.0 Mustangs 4 February 4th, 2008 07:40 PM
