351 heads?
Old March 24th, 2007, 07:53 PM   #1
gregkelley is on a distinguished road
351 heads?
Will 351 heads fit on a 302? I have been told by several people that they will but just wanted some other opinions.
Old March 24th, 2007, 08:21 PM   #2
Stangzilla's Avatar
Stangzilla is on a distinguished road
Well 302 heads fit on a 351 so I would think they do..
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old March 25th, 2007, 05:28 AM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes they do but you will need tappered bolts or studs or head bolt bushings. Now I have to ask, why do you want to put 351 heads on your 302? You will gain nothing, and if you have an 87-93 5 liter you will probably lose horsepower.
Old March 25th, 2007, 02:28 PM   #4
88LSC is on a distinguished road
The E7TE heads are actually 351W truck heads that saved the Mustang power wise for 87.But anyway's the 69-74 heads and the GT40(lighting) are the only good 351W heads.
Old March 25th, 2007, 02:39 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Actually E7TE's were 302 truck heads, hence the 7/16 head bolt holes.
Old March 25th, 2007, 02:58 PM   #6
I thought the 302 truck engines were still using left over E5 heads,and then they decided to cast the E7TE heads with 7/16 holes for use on the 5.0HO and then just drilled them out for the 351W.
Old April 14th, 2007, 09:47 PM   #7
I was just wondering they have been beefed up and have been polished and shaved to raise the compression. The guy only wants $100 for them.
Old April 15th, 2007, 01:38 AM   #8
B.A.M302 is on a distinguished road
Send a message via AIM to B.A.M302
I have 351 heads on my 87 5.0 and I've seen a huge improvement from them .
Crate 302, Trick Flow Intake R, 75mm MAF, bbk 75mm throttle body, bbk 76mm EGR spacer, 351 Winsor heads ported and polished by Bennet Racing, Lunati cam, 30 pd. Injectors, TKO 500, aluminum drive shaft, bbk mid length headers, bbk off road H pipe, 3:55,
Old April 15th, 2007, 01:14 PM   #9
13.64@101mph
if anything just get the hole 351 motor and bore it...screw 302's get some real horsepower #'s!!
Old April 15th, 2007, 02:44 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Exactly how much horsepower did you gain from heads that are almost identical to a 302 head?
Old April 16th, 2007, 01:56 AM   #11
I gained about 65 HP from the heads I had 3 to 5 angle valve, ported polished and bigger intake and exhaust valves installed on them as well as heavy duty springs.
Old April 16th, 2007, 02:21 PM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Just out of curiousity what is the casting numbers on these heads? If you gained 65 horsepower from a set of ported stock heads, you know a secret that alot of engine builders would kill for. There are people that don't gain that with aftermarket heads......
Threads Similar to: 351 heads?
GT 40 X Heads. Need Help Deciding On These Heads, Or AFR`s BillR1970 Parts 8 May 12th, 2009 10:01 PM
GT40 heads vs GTP heads 99TurboV6Stang 5.0 Mustangs 9 September 18th, 2007 10:34 PM
RHS heads , are they good cylinder heads? hitorx 5.0 Mustangs 25 May 12th, 2007 10:55 PM
289 Heads ezra27 General Tech 0 December 31st, 2006 12:09 AM
Boss 302 Heads Same As Cleveland Heads? ken5_0 Classic Mustangs 8 September 25th, 2006 04:18 PM
