I ran a 9.5 in a 8th help
Old March 24th, 2007, 10:02 PM   #1
stang boi 91 is on a distinguished road
here's what I got 3.73 rear with auburn posi 540 lift cam exhaust I have good m/t tires underdrive pulleys i don't think my score is too good i have some edelbrock heads and a 70mm tb that I have'nt put on yet but help me out what do I need to do to get that time up cause I was really dissapointed
Old March 24th, 2007, 10:06 PM   #2
Damn man, that must be shitty driving. My stock AOD launching at about 1500 ran just a little slower than that...
Manual tranny or Aod? Maybe the time effed up! I have no idea. No ragging on ya because i havent been back with the few mods i have done since my stock run, but that is slow with the mods you had on.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old March 24th, 2007, 10:24 PM   #3
5literJeff is on a distinguished road
Send a message via AIM to 5literJeff Send a message via Yahoo to 5literJeff
Can you list some more information like your 60 ft time and 1/8 mph, track elevation, etc.
Also how was your launch, did the car spin or bog? What rpm did you leave? What rpm you shifted at? What was the track conditions?
I had a buddy in his 93 coupe running 8.70s (1100 elevation) here on a stock motor with slicks and a 3.73 and some good launches but hes a pretty mean 5 speed driver.
Old March 24th, 2007, 10:51 PM   #4
my 60ft was 2.2 sec. 330ft was 6.2 sec. 594ft was 8.9 I launched at about a 1500 rpm and I shifted out at about 5,000 rpm I can drive pretty good oh and the track condition was good about the bobble it did at 1st and then it picked up pretty quick my car is a aod
Old March 24th, 2007, 10:54 PM   #5
What about mile per hour?
Old March 24th, 2007, 11:02 PM   #6
75mph
Old March 24th, 2007, 11:14 PM   #7
Well if your running a trick flow stage 2 cam with stock e-7s and a stock aod converter I can see where the problems coming from.
With a cam like that you really need better heads then stock on it. Also you need a converter in that AOD to get that stall speed up and some higher torque multiplication to get that sled moving and makeup for the power loss from a 5 speed.
You say you have the edelbrock heads and havent put em on yet right?
I would go for adding those heads next and maybe a 97 1/2+ explorer intake if you are on a budget. Then get a decent torque converter at least 2800 stall and a must have if you do a converter is a better transmission cooler (with electric fan preferably) and you should be good to go.
Your 60 ft times for an aod isnt horribly bad but it could be much better. With a good converter alone and stickies you could pickup 2-3 tenths in the hole which is good for even more at the end of the run usually.
Old March 24th, 2007, 11:23 PM   #8
+1, your 60' and 330' were both faster than me. my 1/8 was at 9.9, but that was everything stock right down to the factory air box.
I thought gears and slicks would have you in the very low 9s or high 8s at least...Maybe i am wrong though.
[SIGPIC][/SIGPIC]
Old March 25th, 2007, 09:30 PM   #9
tag team's Avatar
tag team is on a distinguished road
yeah my ride when I first got it ran 9.1 all day with msd 6al 373 gears trick flow upper & lower manifolds c4 revears valve body tranny. I too was not happy! but my problem was getting out of the hole too sluggish. so i put a 3000 stall in it but have not run it yet to see how much differance it made.. but this friday i will see & let you know the differanceit made im sure it's a lot
all 4 one & one 4 all
