Rocker arm questions
Old March 24th, 2007, 10:04 PM   #1
Maxwell881 is on a distinguished road
I am going to replace the 1.7 crane roller rockers with another set to see if I can't eliminate some valve train noise. The new set of crane 1.7 rockers are identical, except for one thing, the fulcrum pivot seat. The set that is on the heads right now has this double fulcrum seat with radius's milled into the bar to house both exhaust and intake. The new set uses a type of individual nut that sits on a .03 thick piece of channel that houses both nuts for intake and exhaust. What I need to know is, can I just swap these rocker sets from one to the other without damaging anything in the motor?
Old March 25th, 2007, 04:26 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Are you sure you don't have a set of stud mount and pedestal mount rockers? Do you have pictures or a link to a picture of similar rocker arms?
Old March 25th, 2007, 07:24 AM   #3
I do not have a picture or a link to any picture. Both of these sets of rockers uses what I believe to be a 5/16-18 bolt to hold down the rocker into the head. One set uses a Torx T-45 head and the other uses a 1/4 Allen wrench, I am pretty sure that these are not stud mounted, either one.
Threads Similar to: Rocker arm questions
Roller Rocker help sniperrider 5.0 Mustangs 12 August 31st, 2007 10:00 PM
roller rocker ? marcd 5.0 Mustangs 15 June 25th, 2007 10:35 PM
03-04 Cobra rocker panels? HELP! Orangester Visual 1 June 18th, 2007 10:12 AM
Rocker panel stripes ByPopularDemand V6 Mustangs 13 April 8th, 2007 11:11 AM
Rocker Panel Stripes? WeCircleTheProblem Visual 14 February 11th, 2007 10:33 PM
