dizzy help
hey guys, i took my distributor out to replace my intake gaskets and now i cannot the the damn thing back in.
for some reason i cannot get the oil pump drive to go back in it. some advice and help would be great. TIA Nate |
Bump the key to turn the engine over. It will drop right in.
no dice, for some reason i cannot get the oil pump shaft to stay straight.
ive honestly never had this issue before. |
The shaft will not stay straight but the hex top is beveled so it will straighten out and slide into the distributor. Try again, its not that complicated of a procedure.
#5 | ||
88Notch 10.59 @132 / 03 Mach 1 13.1 @104
Use this
![]() ~~Edit~~ This is a joke
Military Crew USMC
1995 Mustang
Prev best of 11.8@11?
i have the same problem when i take my dizzy out
takes at least 2 mins and a magnet stick to get er in right |
#7 | |
1991 Mustang LX 5.0
![]() What comes out, must go back in.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1993 5.ohhhh
12.97 @140mph
There has been similar threads like this. I never had this problem with the stocker or my arp dshaft, which may as well be stock. I have friends who own srt-4s take my dizzy in and out. Just play with it.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
wheni pulled mine out i had to kinda turn it clockwise to get it in make sure you mark it though dont wanna be one tooth off even.
found out my issue.
when i removed my dizzy it pulled the oil pump drive shaft out of the pump and was just sitting in the block.
but first, i went out there one morning after work and the dizzy just fell in... i fired it up and had no oil pressure and immediately shut it down. without knowing what was wrong i went to oreilly's and bought a new dizzy, new mellings high flow oil pump. today i am finishing it up... and im also putting some free headers on there as well |
89 GT
Were you going by a mechanical gauge or the stocker?
mechanical. i was reaching over the motor after bridging the starter and was hearing the lifter ticking pretty loud...
#13 | |
How long did you run the car when you thought it had no oil pressure? How long did the car sit since the last time it ran? Its possible that you didn't let it run long enough. Kind of like after you change oil and it takes a few seconds of running for the gauge to show oil pressure.
i did the same thing....come to find out when i blew my oil pump shaft...i got a new one and put it in upside down...which was fine ...till i pulled the distributer and out the shaft come and dropped tothe oil pan after i tried to straighten it out threw the distrib hole
Threads Similar to: dizzy help
| Dizzy question | 707Stang | 94-95 | 2 | April 27th, 2009 05:50 PM |
| What Dizzy? | ken5_0 | Classic Mustangs | 3 | March 25th, 2008 07:10 PM |
| 87 dizzy replacement to older style | beheivjer | 5.0 Mustangs | 7 | December 25th, 2007 09:56 AM |
| Witch MSD Dizzy | tag team | 5.0 Mustangs | 11 | October 24th, 2006 10:12 AM |
