LinkBack (1) | Thread Tools |
#1
92 Mustang GT
92 mustang EFI to carb swap.
Im currently goin thru the process of switchin my 92 5.0 over to carb set. I bought a new Edelbrock RPM airgap intake and a complete MSD ign. setup.
i have Ran into a few snags so far a few bolts broke off into the heads while taking the lower intake off. Seeing as how the motor has 150k on it i wasnt shocked. So i picked a 90 302 ho motor with 66k to replace mine with for now. I was just goin to swap the heads but figured this would give me the chance to clean up the firewall and engine bay. ANy suggestions on how to smooth out the firewall?? Pulled the motor out tonight goin to start on cleaning the engine bay up etc tomorrow. Few ?s will my flywheel and balancer work on the 90 motor fine? dunno if they change the weight at all or not. what should i use to plug the EGR holes n the back of the heads? for now the original motor will b put on the stand and eventually be rebuilt with alot of xtra goodies =-) n ready to go back in over the winter. Last edited by MustangMatt96GT; August 1st, 2010 at 12:21 AM. |
92 Mustang GT
1991 Mustang LX 5.0
Smoothing out the firewall requires welding plugs in all the holes, and then bondo, primer, and paint. Yes, your flywheel and balancer will work. They are the same. Plugging the egr passage in the heads is easy... go to the local hardware store with the equalizer tube and get the same size bolt. Sorry, don't remember the size off hand.
BTW.... Why would you ditch the efi???
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
#4 | ||
88Notch 10.59 @132 / 03 Mach 1 13.1 @104
^^ Ditching EFI seems to be a growing trend..
Military Crew USMC
1989 Black LX---Turbo
WHY, WHY, WHY? This is 2010 People!!!! Carburators are for lawn mowers & Race Cars!
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
fixed it for you.... EFI is far superior to carbs in EVERY way. end of story.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
1986 LX NOTCH
cause it is cheaper see the price of efi parts then u have to get tuned hope the tuner knows what he is doing.
86 TRUNK 359w-SRP 8:1-GT40Ps-X303-MAC LONGTUBE'S-VICTOR JR INTAKE-850 HOLLEY-T-5-410's-150 shot |
#8 | |
plus, the EFI setup is far more detailed in the control that it gives you. When I go from track to track, I dont have to re-tune for DA, like carb runners do
92 Mustang GT
I just dont have the patients to chase down sensors etc when shit goes on. WIth a car thats almost 20 years old sensor start goin bad left n right. Two it is way cheaper then buying injectors, bigger mass airflow etc. Its really just way simpler to tune a carb then a EFI setup for me seein as how I dont have alot of experience with tuning the EFI . thanks for the info fast stang. I figured that would be the best way to smooth out the firewall.
#10 | |
1986 LX NOTCH
Proud American
Both have thier advantages... I personally like the carb route because of the flexablitiy with a jet kit, blocked off power valves, a screw driver and knowing how to read a spark plug...
For a DD that was just that something to drive to and from work, i would stick with an EFI setup... My car can be DD just fine, but is more of a race car.
1986 lx notch
9.98 @ 135
![]() " Spending money I don't have.... on things I don't need .... to impress people I don't know " . |
1991 Mustang LX 5.0
I'm gonna call BS on that. Obviously the car WAS NOT tuned properly with the EFI, but also, when they switched to carb, IT GAINED AN ELECTRIC WATER PUMP!!! And who knows what else was changed in the process.
89 GT
That video is not accurate at all. For starters, what intake did they put on with the carb swap? That alone could have been worth a good chunk of the gain, because the 2 piece intake was probably choking that motor to begin with. Look at the powerband for that engine. I'll bet they put a single plane intake on it and thats what woke it up. I'll also agree that that EFI car probably wasn't tuned properly to a small degree. And, if you had a cam optimized for EFI, chances are it wasn't designed with carb signal in mind, so most likely, switching to a carb alone wouldn't net a gain. Unless that cam was better suited to run a carb to begin with and wasn't running to it's full potential with the EFI on there.
EFI for the win.
You carb lovers can justify using those fossil carburetors all you want. I will continue to use EFI and blow your doors off and get 25 mpg while doing it. Back in 2000 I was running 11.50s and getting 25mpg on the highway with a factory Ford EFI system in a 91 Mustang GT. Do that with a carburetor.
#16 | |
very very subjective and controversial video... for all we know, the car could have had a 70mm TB on it before...
I doubt you would see similar power gains in a car like mine... with its 90mm TB and Super Victor style intake.. Shit. my car would be a perfect car to test that on since I have a carb ready lower intake...
#18 | ||
What size engine do you have?? I love how those intakes look and you dont have to remove much to adjust your rockers
Military Crew USMC
#19 | |
Proud American
If I could have and would have knonw more about the computer systems in these cars, I would have mine EFI right now... But I can say that I have learned a HELL of a lot about carburators since I ran one.... But because of the efficency of EFI I would love to have it in my car. And actually have an A9P computer now and 5.0 harness for when I wanna convert my 351 to EFI
#20 | |
and its a 347
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/176692-92-mustang-efi-carb-swap.html
| Thread Mustang mods - why are these 2 mods done on EFI Stangs sometimes? | Corral Forums | BoardReader | This thread | Refback | September 17th, 2010 04:40 AM | |
Threads Similar to: 92 mustang EFI to carb swap.
| how to swap from EFI to carb? | demonicus | 5.0 Mustangs | 13 | January 16th, 2010 04:16 PM |
| EFI to Carb Swap | 98stangv6 | 94-95 | 0 | September 12th, 2009 12:12 PM |
| EFI vs Carb | scxc15 | 5.0 Mustangs | 61 | February 20th, 2008 08:55 AM |
| EFI to Carb swap? | JONJON | 5.0 Mustangs | 3 | September 22nd, 2007 05:54 PM |
