gasy smell in the oil
Old April 17th, 2006, 12:13 PM   #1
Bill is on a distinguished road
is this normal for the oil to smell like is has a little gasy(fuel) smell to it.
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!!
Old April 17th, 2006, 12:47 PM   #2
mdvaldosta's Avatar
11.47@120.58
Well, their both petroleum based... there would be no way to get fuel into your crankcase in a fuel injected car unless you've got a leaky injector. If in doubt, change the oil.
Old April 17th, 2006, 12:48 PM   #3
fakesaleen's Avatar
1988 lx t-top
fakesaleen is on a distinguished road
does it smoke
http://i723.photobucket.com/albums/ww234/wendell1988/fakesaleen.jpg
Old April 17th, 2006, 01:01 PM   #4
yeah it smokes alot when i dont start it for a while. and when i let it idle or drive it it reaks of gas.
Old April 17th, 2006, 01:01 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
or by running a 160 degree thermostat...
Old April 17th, 2006, 01:03 PM   #6
i dont know what thermostats in it. im guessing what ever stock is. this car is pretty much all stock except for flowmaster mufflers and knn filter and random stuff i replaced on it but no performance stuff.
Old April 17th, 2006, 02:18 PM   #7
OTreborO is on a distinguished road
I had a similar problem with an old s-10
I was somehow getting oil in the gas, so bad that when I was pulling a camper, it would jump/almost not run, I changed the oil, and problem went away, then I sold the truck. I am sure it was some kind of sensor or something that was causing th issue, but no one could identify the problem.
Old April 17th, 2006, 05:39 PM   #8
fakesaleen's Avatar
1988 lx t-top
it sounds like a bad piston ring
Old April 17th, 2006, 08:54 PM   #9
173speed is on a distinguished road
that would be my guess 2
SEEYAAAAAAAAAAAAAAAAAAAAA MOTHER @#$%
Old April 17th, 2006, 08:56 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
A bad piston ring would have worse issues than a little bit of gas in the oil.
Old April 17th, 2006, 09:25 PM   #11
what color is the smoke ?
Old April 17th, 2006, 10:12 PM   #12
when you really step on it you can see that the smoke has a blue to it. and i also know that i get alittle oil in the egr spacer.
Old April 18th, 2006, 09:11 PM   #13
does it use oil ? i think that u are burning oil hens the blue smoke maybe do a compression test on it and see in what condition the valve seals and piston rings are
Old April 18th, 2006, 09:39 PM   #14
well i havent really drove it in a while but i lose most of the oil cause of the bad oil pan gasket and bad rear main seal. when i do drive it it drives pretty good. IDK. i wish i had a place to work on it tho.
Old April 19th, 2006, 03:10 PM   #15
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
the burning of oil on startup could be bad valve guides/seals?
Old April 19th, 2006, 03:16 PM   #16
so it would be a good idea to get the motor rebuilt or get a new long or short block.
Threads Similar to: gasy smell in the oil
I SMELL MY CLUTCH???? GeNos86GT 5.0 Mustangs 11 September 14th, 2007 01:25 AM
I smell raw gas when i turn on my a/c.... 94pacecarSVT 94-95 0 June 23rd, 2007 11:15 AM
Oil Burning Smell Off and On....?? 98mustangfla V6 Mustangs 3 April 2nd, 2007 10:03 AM
Burning Smell When Heat Is On soccerchic2143 2.3 Mustangs 4 February 3rd, 2007 07:44 PM
Gas Smell Since I Filled Up Last, This Is New 91GRNGT 5.0 Mustangs 16 November 25th, 2006 12:54 AM
