Thermostat
Should i change the thermostat in my car? Can you get additional performance by doing so? If so what kind?
SUP MAN!!
To be honest you might feel the performance difference. I have a 160* in mine right now and it runs perfect. Most people will say 180* is good which I do beleive but I'm always going for the extra. I would say a 160 if you've had some mods done. I run a little cool but my car sure as hell runs great
THE BEAST IS FOR SALE!!! GTX RACING & PERFORMACE CLUB OF TEXAS Meets and greets, drag racing and good eats, you know you want it. GTX Racing Tony P. 214-257-3635 http://www.moddedmustangs.com/forums...vehicle&CID=43 |
1988 Mustang LX Turbo
well guys with modded engines change the thermostat from the stock 180* to about 160-175* there really is no gain from it except when the negine reachs that temp. it opens up and allows the water/anti-frz in and thru the water jackets cooling the cylinder walls, but like i said there really is no gain
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
180 is fine - I run a 160 in mine cause that's what KB recommends, but I read that the lower the thermostat, the more cylinder liner wear increases...
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
2001 svt cobra
no way (IRS)
is the stock 190 or 195
Build #1249 MM New Edge Crew Member# 6 |
I know its higher than 180*
#7 | |
#8 | |
Re: Thermostat
I dont know about a performance gain but Moroso makes a nice high flow piece that I have but I also have a high flow water pump so I figured it would aid in water flow.. If you are lookin to change it cuz you are gonna get more hp its not worth the time or effort..
Threads Similar to: Thermostat
| Thermostat.... | lwhitetrash88l | V6 Mustangs | 3 | June 19th, 2007 04:36 PM |
| thermostat ??? | lugthug713 | 94-95 | 6 | June 15th, 2007 02:10 PM |
| thermostat | JBIGBOOTSY | 5.0 Mustangs | 2 | May 24th, 2007 09:35 PM |
| Thermostat | Onemanzu | V6 Mustangs | 2 | April 20th, 2007 08:00 PM |
| thermostat | VSR13 | V6 Mustangs | 7 | February 22nd, 2007 05:46 PM |
