Discussing roller vs. non roller block in the 5.0 Mustangs Forum. newbie just trying to get some answers. what is the difference between the two? should ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
roller vs. non roller blockshould i avoid a non-roller block? can you turn a non-roller into a roller? I'm looking at a shortblock 351w non roller block. am i limited with this block. it seems all the performance heads are for roller rockers...what kind of heads would i have to buy? thanks for the help.... |
They have a retro-fit kit that's very pricey. But I've seen some massive, sturdy power made from non-roller blocks but the power curve will be different. I would look at a retro-kit or see how you can PROPERLY change your non-roller cam and lifters, to roller.
THE BEAST IS FOR SALE!!! GTX RACING & PERFORMACE CLUB OF TEXAS Meets and greets, drag racing and good eats, you know you want it. GTX Racing Tony P. 214-257-3635 http://www.moddedmustangs.com/forums...vehicle&CID=43 |
1990 Mustang LX
9.36@143 mph
Roller blocks are blocks that had factory roller cams. They can use factory lifters and hardware. Non roller blocks can still use roller cams but you either need to get a retrofit kit or buy aftermarket roller lifters. I prefer the older non roller blocks because they are stronger. Newer blocks have alot of "corners cut" to cut costs.
You can put roller rockers on any heads. Buy the heads that fit your combination and then buy roller rockers for that particular head.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
I got that retro-fit tips and other from Darrell as well, thanks to him I also verified that the 351 I looked at IS a 351. Haven't run the numbers yet so I can get the year
83 coupe
so basically i can take my non roller 302 and put a roller cam and roller lifters in it and tadaa it will work, is there anything else u have to change to do this or what????
#6 | |
so will a new roller cam be all i need if the heads come with the roller/rockers? Will the heads bolt up fine to a non-roller block?
Thanks |
Yes the rockers have nothin to do with the block, And yes the heads will bolt up if they are for that motor. Do you know what a rocker is?????
obviously from my question Im somewhat confused as to what a rocker is.
I thought I understood and then came across non roller short blocks. On a short block at what point does it become a roller block? Yes i'm knew to all of this and just trying to get well informed. I appreciate the help. DJKING |
83 coupe
"You said the same thing when i asked about non-roller and roller.... Watch what darrells gonna tell ya"
i just wanted a good conformation so if i go to change out my cam i can get a roller cam and change out the lifters and all of that, but i have a non roller right now |
so whiteboy is it just the cam that needs to be changed to a roller cam?
83 coupe
im not to sure thats what im trying to figure out im sure the cam and lifters as far as anything else im lost
Threads Similar to: roller vs. non roller block
| Non roller 302??? | shurb125 | 5.0 Mustangs | 1 | June 13th, 2007 06:39 PM |
| Hydrolic roller to Solid/Mechanical roller | hitorx | 5.0 Mustangs | 2 | May 14th, 2007 05:12 PM |
| Production roller block @ 1100 HP | Zak | 5.0 Mustangs | 10 | April 24th, 2007 08:50 AM |
| roller??? | cali 5.0 | 5.0 Mustangs | 15 | March 22nd, 2007 03:49 PM |
| what would you pay for a roller | Tony_90fox | 5.0 Mustangs | 10 | December 2nd, 2006 04:36 PM |
