Bump steer kit???
Old March 29th, 2007, 09:20 AM   #1
lugthug713's Avatar
2002 Roush 360R
lugthug713 is on a distinguished road
Bump steer kit???
Hey just wondering what does the bump steer kit do?
Old March 29th, 2007, 10:00 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Corrects the angle of the tie rod ends to eliminate "darting" when you hit bumps or irregularities in the road.
Old March 29th, 2007, 12:25 PM   #3
lugthug713's Avatar
2002 Roush 360R
So is it a good up grade? I am going to do suspension and and I think I might need a new rack n pinion steering wheel has play in it. But I want suspension for driving on road not drag. Any sugestions?
Old March 29th, 2007, 12:40 PM   #4
FaStStAnG5-0's Avatar
FaStStAnG5-0 is on a distinguished road
Send a message via AIM to FaStStAnG5-0
i'd say that the upgrade is worth the money!
http://www.cardomain.com/ride/2461223
1994 GT: MSD 6AL, BBK O/R H-Pipe, Dynomax Race Bullet mufflers, 3:73 rear, Hurst Short Shifter, MAC cold air intake & much more coming soon!
Old March 29th, 2007, 12:54 PM   #5
j2000_guy is on a distinguished road
i just did eibach 1.5", steeda ball joints (1/2" drop in f), steeda bump steerkit, energy susp. poly bushings, energy swaybar endlinks, KYB agx Struts shocks. It handles like a true road car now. definately worth the money!
94 cobra, headers, CAI, h-pipes, flowy 40 series, short throw, underdrive pulleys, 3.73's
Old March 29th, 2007, 01:06 PM   #6
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
Pretty much what Darrell said it places the tie rod in the correct correlation to the control arms. If your not getting bumpsteer now than no need for them.
The slop in your wheel is more then likely from a beat rag joint in your steering shaft. I do run the bumpsteer kit with my set up (eiback pro kit, MM caster cambers, Tocikos, MM steering shaft, Aluminum rack bushings and steeda endlinks. Handles like a champ.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Threads Similar to: Bump steer kit???
Bump Steer Kit Garhfer 99-04 7 November 3rd, 2007 08:51 AM
Bump steer kit??? lugthug713 94-95 3 June 22nd, 2007 02:28 PM
bump steer kits?!?!? noppe180 96-98 1 June 12th, 2007 11:08 AM
bump steer kits? THE GT-40 KID 5.0 Mustangs 2 May 28th, 2007 11:23 AM
Bump Steer stang94 94-95 2 April 21st, 2007 07:20 PM
