Need T5 Reshim Help (E3Sean)
LinkBack (1) Thread Tools
Old August 17th, 2010, 10:05 PM   1 links from elsewhere to this Post. Click to view. #1
1990 5.0 Smokin' AOD LX
14.27@100.77
Siegedg505 is on a distinguished road
Ok so I was trying to reshim my T5 like this (How To Shim The T5 Input Shaft), and so parts fell out. I'm pretty sure that i am going to have to replace these parts but here the pics of the droppings.
and here is the retainer
any help is appreciated
90 Mustang LX 5.0 T5 swapped,Mac CAI,intake,Timing,E-Fan,headers,H Pipe,Dumps,Gears,Control Arms,and diet
http://www.fictionalversus.com/index.php my second love
Old August 22nd, 2010, 03:24 AM   #2
e3sean's Avatar
1988 lx
9.68@142
look at your mainshaft i bet it is all effed up. its gonna have to be fixed as well
<font size=4><b>MILITARY CREW
Old August 22nd, 2010, 07:32 PM   #3
14.27@100.77
The main shaft looks ok, but i'll inspect it again. I ordered a new bearing to replace the old one
Old August 22nd, 2010, 08:38 PM   #4
e3sean's Avatar
1988 lx
9.68@142
at first it looked like that was the loose needel bearings that ride on the mainshaft now i see that is the input shaft bearing. that is uausally caused fron running low on fluid. easy fix. new bearing retainer and new input bearing/ race.
Old August 23rd, 2010, 01:12 AM   #5
14.27@100.77
cool I'll order a new bearing retainer. Thanks man!
Old August 29th, 2010, 03:23 PM   #6
14.27@100.77
so what is a good sealant for the bearing retainer?
Old August 29th, 2010, 07:16 PM   #7
14.27@100.77
Ok so I have a new issue, my bearings won't fit over the base of the input shaft. The bearings will fit over the snout (where the shaft engauges the flywheel) but not over the base (where the inout shaft sits inside the tranny housing), it's not wide enough.
Old August 29th, 2010, 09:00 PM   #8
1992 Lx
11.39@119.24
rtv
the needle bearings?
Old August 30th, 2010, 07:27 AM   #9
14.27@100.77
It's part number 98 in this picture
Rockland Standard Gear, Inc. | Tremec T5 Non World Class 5-SPD Transmission
and this is the exact piece I bought
http://www.mustangsunlimited.com/ite...sp?T1=A%2D5+01
Old August 30th, 2010, 08:08 PM   #10
e3sean's Avatar
1988 lx
9.68@142
it gets pressed on. how did you get the old one off?
Old August 30th, 2010, 08:17 PM   #11
14.27@100.77
ok that makes sense, I never removed it. If you look in the first pic it looks like it got shredded.
Old September 3rd, 2010, 12:49 AM   #12
14.27@100.77
Any ideas of where I coul dhave it pressed on? Shouldn't any transmission shop be able to do it?
Old September 3rd, 2010, 01:09 AM   #13
e3sean's Avatar
1988 lx
9.68@142
if you have a vice and a bearing seperator or an air chizel the old one is easy to remove even a hammer and a chizel will get it off. the new one is easy to install. get a peice of pipe the right size and use a hammer to hit the new bearing on just have the base of the input shaft sitting on a flat hard surface like a plate of steel or the concrete will work too. or if you have access to a press that will work too.
Old September 3rd, 2010, 01:13 AM   #14
14.27@100.77
ok thanks, i'll get on that tomorrow.
Old September 3rd, 2010, 10:29 PM   #15
14.27@100.77
And this really works? Do I need to use any lube or anything to help the bearings slide onto the input shaft?
Old September 4th, 2010, 04:36 PM   #16
e3sean's Avatar
1988 lx
9.68@142
you can but no and you can put the input shaft in the freezer for an hour or so to help but i never do.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/179452-need-t5-reshim-help-e3sean.html
Thread How To Shim The T5 Input Shaft | Forums at Modded Mustangs | BoardReader This thread Refback October 9th, 2011 09:54 PM
Threads Similar to: Need T5 Reshim Help (E3Sean)
e3sean 91sleeper The Clubhouse 17 May 3rd, 2010 06:46 PM
e3sean, how did you do? fateisajester 5.0 Mustangs 0 October 24th, 2008 10:16 AM
e3sean chickenbot 5.0 Mustangs 12 June 21st, 2008 03:09 AM
e3sean chickenbot 5.0 Mustangs 3 May 12th, 2008 09:00 PM
hey e3sean u might like these 91cobra5.0 5.0 Mustangs 1 March 2nd, 2008 11:53 AM
