Fuel Pump Problems
Old March 29th, 2007, 05:16 PM   #1
bigbadtalontsi is on a distinguished road
Fuel Pump Problems
So i have put 5 new fuel pumps in the car in the last 2 months. I put 3 new factory pumps then i sprung for 2 walbro pumps. Why would my car keep killing the pumps. Is it nesessary to rewire the pump? My car is down at the moment and i want to figure the problem out before i spend another hundred dollars on a pump. Thanks
Old March 29th, 2007, 05:27 PM   #2
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
Have you replaced your fuel filter at all? I dont see any reason why you would burn through that many pumps unless it was being over worked ie.. clogged filter. Any problems with the way its running? any codes?
Maybe check the voltage to the pump for chits and giggles and see what you got. Seems like a very odd problem.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old March 29th, 2007, 05:39 PM   #3
GTXRacing is on a distinguished road
Hve you checked under your seat to make sure there's nothing wrong with the Fuel pump Relay
THE BEAST IS FOR SALE!!!
GTX RACING & PERFORMACE CLUB OF TEXAS
Meets and greets, drag racing and good eats, you know you want it.
GTX Racing
Tony P.
214-257-3635
http://www.moddedmustangs.com/forums...vehicle&CID=43
Old March 29th, 2007, 05:50 PM   #4
I pulled the plug off the fuel pump and checked the voltage. When the key was on (not running) the red wire was receiving 6 volts, the yellow was about the same. When i check the red going into the fuel pump housing when the car is running it is showing 12v. This has got me baffled.
Old March 30th, 2007, 02:38 AM   #5
db83stang's Avatar
db83stang is on a distinguished road
i would go ahead and check your grounds also trow a new relay at it just to eliminate that they are cheap, then go from there. +1 on the fuel filter i have seen a clogged filter destroy a new pump in like one tank of gas.
Old March 30th, 2007, 05:50 PM   #6
Already replaced the filter a few month ago
Threads Similar to: Fuel Pump Problems
1998 Chevy Fuel Pump Problems mattstang All Other Vehicles 5 December 18th, 2007 12:10 AM
Gas pump problems AnimalCrackers 2005 - 2010 9 July 13th, 2007 10:37 PM
fuel pump fuel pressure stuff JBIGBOOTSY 5.0 Mustangs 2 April 26th, 2007 04:31 PM
HUGE PROBLEMS....IDLE, AIR/FUEL/FUEL PRESSURETPS HOW TO SET? 1slowhatch 5.0 Mustangs 0 April 21st, 2007 07:48 PM
Fuel Pump problems petro68 5.0 Mustangs 5 August 24th, 2006 07:12 PM
