#21 | |
1991 Mustang LX 5.0
Sorry... I researched it enough myself in the last month to know it's not just gonna run you a couple hundred more. I'll go with a couple thousand more, since I'm looking at the WHOLE picture.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
#22 |
This must be a misprint.......
#23 |
1992 Mustang LX
13.0 @ 105
Why not a 351W based motor? As the others said; too much money comparitively. I am also going to go the forced induction route so I can make as much as an N/A 408,427 etc. 302 based parts are very cheap in the whole car hobby. But seriously guys, I need an idea of where to start. I need to know what kind of block/rotating assembly would be good for some power and a turbo. I'm almost positive my heads will be trick flow I just don't know what size would be appropriate for a stroker. Thanks.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
#24 |
89 GT
If you're trying to go 9's (reliably) you're already going to have to buy a new block/internals anyway. you'll also be buying new headers and a new topend. The money you'll spend doing it with an 8.2 deck vs. a 9.5 deck won't be a whole lot more and you can make more power with a 351 based engine. Don't get me wrong, I love a screaming 8.2 deck, and acceleration is what gets you to the finish line faster which an 8.2 deck will do better every time given the cubes are close. Either way, both deck height blocks will do what you're looking to do and the cost difference won't be a whole lot more in the end. But a 9.5 deck height block will allow you room to grow more, given if you do it right, you can turn almost as much RPM and have more cubes.
I'm not discounting what FastStang91Lx said at all though. If you're doing a build where you wouldn't have to change everything, he is absolutely correct. For a car with goals not as high as 9's on a street car, I wouldn't go with a 351 block either. I just look at it thinking you'll never be satisfied with the time you run and will always want more. |
#25 |
A 9 second car is going to cost you a minimum of $15,000 and that is assuming you have the car and some of the parts already. Its easy to build the horsepower. What you have to factor in is the suspension, roll cage, chassis strengthening, wheels, tires, axles, axle bracing, fuel system, seats, seat belts, SFI approved parts, parachute, etc. I've done it and its expensive.
#26 | |
1990 LX hatch
I wish I could have seen u deploy your chute....
#27 |
1992 Mustang LX
13.0 @ 105
Yea i know what it entails such as all of that safety stuff too...Just giver me a starting point. That was the point of this thread and i haven't gotten any block,rotating assembly,heads,cage etc. to look at.
#28 |
89 GT
Dart iron eagle block from woody, go 445 cubes. TEA 235 highports or better, ported super vic (or super vic EFI), custom billet cam. Tubular K member, tubular a arms, coil overs front and rear, cage, motor plates, full rear suspension kit with ARB (Team Z is my first choice), Accufab headers, pro systems carb if your going carb or your choice of tuner if you're going EFI. Faceplated toploader if you want stick, I don't know jack shit about autos. 9" ends on your rear and rearend bracing/gussets, slicks, skinnys and a whole lot of supporting mods that I forgot to mention.. ect.. If you want more, spray it, boost it whatever, just take that into consideration before you build it.
#29 | |
You sure could skip alot of safety stuff and still go fast and do it cheaper but its stupid and unless you go to 41 or another track that runs a similar program you will never get to race the car. Most of the time I never used my shoot or even had it on the car because it wasn't fast enough. ![]() 145mph requires a chute. I couldn't get that piece of shit to go faster than 143mph. The chute sure did look pretty though.
#30 |
1991 Mustang LX 5.0
Is 41 a track, or a speed/certified point? Sorry, don't know squat about tracks yet.
#31 | |
1990 LX hatch
Oh, I ment poop chute not parachute.
#32 |
1990 LX hatch
Also as a matter of fact I just got back from there. Me and my son went, we were greeted at the gate by a half naked girl. She said no dice, its 18 and over tonight. I was pissed. My 10 yr old son had his eyes locked on the hoochy, it was priceless.
Nothing like wasting a 5 gals of gas, and driving 70miles round trip in my hot ass fox.
#33 | |||
Threads Similar to: New combo
| Anyone with this combo? | notch9350 | 5.0 Mustangs | 0 | April 4th, 2008 06:25 PM |
| Need Combo Help | 1BADSTANG | 5.0 Mustangs | 15 | March 31st, 2008 12:51 PM |
| What Does My Combo Need? | 82GT | 5.0 Mustangs | 18 | November 16th, 2006 07:56 AM |
| 12 Second Combo | Tim Stewart | 5.0 Mustangs | 3 | September 21st, 2006 05:34 PM |
