What are these wires
Old August 21st, 2010, 01:57 PM   #1
Stangin94GT's Avatar
1994 Mustang GT
Stangin94GT is on a distinguished road
There is 2 of these. They run from drivers side firewall. the other end of the box looks like a wire was running out of it and cut off. And inside the box mayve a fuse or something goes in it?
And then these 2 wires I dunno. one is red the other is purple and white. The red has never ran to anything that Im aware of since I had the car. I believe the purple and white wire ran to my ignition coil before I took engine apart. friend said it may be for my monster tach? They come from same area as the other 2 with the box
Old August 21st, 2010, 02:45 PM   #2
fogged306's Avatar
89 GT
The top one isn't stock so it could be for anything, but it shouldn't be anything that wont make the car run. It it is fuse holder. Not sure about the bottom ones though. If it went to your coil it could be for a tach or an ignition box. Do you have anything like that or just the tach?
Old August 21st, 2010, 03:00 PM   #3
1994 Mustang GT
Not sure what ignition box is. I do have a monster tach. Its been acting up before the rebuild. It floats and sometimes wont move, or just reads way off. I want to take it out, but I like it lol
Old August 21st, 2010, 03:04 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
They are not factory wires.
Threads Similar to: What are these wires
Help hiding sub wires.. whyxitx V6 Mustangs 6 August 1st, 2010 11:20 AM
need some help with some wires 707Stang Classic Mustangs 13 June 25th, 2009 10:41 PM
Where Did These Wires Go? mustang1072 V6 Mustangs 21 December 8th, 2007 02:10 PM
New Wires 96GtGoodz 96-98 8 November 20th, 2007 08:36 PM
wires skid6 5.0 Mustangs 1 June 18th, 2007 12:22 PM
