new times.
Old August 22nd, 2010, 09:05 PM   #1
JBIGBOOTSY's Avatar
1990 LX hatch
new times.
1st pass, 10#, left with no 2step: 11.2492 @ 128.41 Shakey as hell, car was all over the place. I lifted. I did a short burnout. 1.82 60"
2nd pass 12#, left at 4800 on the 2step. 10.2527 @ 127.55 It felt sooo good. Power shifted perfect every gear(1st time that I never missed a gear)
I will soon hit 9.99 that is my new goal. I'm stoked!!!
Old August 22nd, 2010, 09:11 PM   #2
1992 Lx
11.39@119.24
you cant run that fast with an on3 kit it would fall apart
Old August 22nd, 2010, 09:12 PM   #3
fogged306's Avatar
89 GT
Congrats, looks like you hooked a lot better on the second run. Whats the combo you're running? ... and how the hell did you lift and still run more MPH than a perfect shifted run?
Old August 22nd, 2010, 09:43 PM   #4
JBIGBOOTSY's Avatar
1990 LX hatch
I have no idea, about the mph. I lifted around the 1/8 mile the first run, corected, and got back in it. I should have clarified that.
it hooked decent the first run, the second run was picture perfect. If you dont powershift with this goofy blow off valve vents all the boost, and you have to spool back up EVERY damn shift. Poershifting solved that. my other option was just to un-plug the vac line to the blow off valve.
I'm thuper exthited tho.
Old August 22nd, 2010, 09:45 PM   #5
JBIGBOOTSY's Avatar
1990 LX hatch
It did. it shot chinese fetuses out the hood.
Old August 22nd, 2010, 10:00 PM   #6
fogged306's Avatar
89 GT
The new bio-fuel.
Old August 22nd, 2010, 10:01 PM   #7
1992 Lx
11.39@119.24
nuts dude. Borderline splitting the block amiright?
Old August 22nd, 2010, 10:08 PM   #8
JBIGBOOTSY's Avatar
1990 LX hatch
I hope not. I hit the 10.2, and I had the urge to push another 4lbs into it, but a good buddy was there, and asked me if I wanted to drive it home, or tow it home. So I left with the low 10, and my block in one solid piece.
No tune on this bitch either... wideband stayed in the 10-11 range from 5500-redline i saw 12's on it. I didnt exactly watch it the whole run tho. so it was safe.
Old August 22nd, 2010, 10:15 PM   #9
1992 Lx
11.39@119.24
brb selling my stroker for on3 kit
Old August 22nd, 2010, 10:17 PM   #10
JBIGBOOTSY's Avatar
1990 LX hatch
As for the setup. this was the farewell appearance of the old setup Its the stock bottom end, procomp 215cc. 2.08" 64cc. fcam, stainless rockers, typoon intake, on3 turbokit. 3.55's thru a t5 30#ers with an 6:1fmu... thats right 90+#'s of fuel pressure. I shit trains...Now what?
The t5 took it, but I noticed, on the return road when I put it in 5th, it was howling loud, only in 5th tho, thats the only gear i dont use in the 1/4. IDK.
Old August 22nd, 2010, 10:19 PM   #11
JBIGBOOTSY's Avatar
1990 LX hatch
THey are dirty cheap. It makes your car sound like a chrystler lhs with no muffler tho.
Old August 22nd, 2010, 10:20 PM   #12
1992 Lx
11.39@119.24
whats the next setup? Seems like a waste to change it up if first trip to the track went this well
Old August 22nd, 2010, 10:51 PM   #13
JBIGBOOTSY's Avatar
1990 LX hatch
Plans were allready in motion. It will be an 8.2 motor. that is all.
I was thinking of selling this fox, as is, or trade for a 25.2, or 25.5 roller, then but the new 8.2 motor in that. THat would take good timing, and all things would have to be in the right place at the right time tho.
Old August 22nd, 2010, 10:55 PM   #14
JBIGBOOTSY's Avatar
1990 LX hatch
also, I have some good expireience at the track, and in my opinion, the 10.2 will not be improved upon without more boost. the car performed as perfect as I could have asked for. I figure its pretty much topped out, and dont wanna make some paperweights. I do wanna get a dyno tho, see if im past the point of breakage or not.
Old August 22nd, 2010, 11:13 PM   #15
302Army187's Avatar
'89 LX 'Vert
10's or bust... Literally.
302Army187 has a spectacular aura about302Army187 has a spectacular aura about
congrats, sounds like a blast.
I too doubted the on3 kit, but more and more it seems they are holding up well, and performing right.
What are your suspension mods? Also what is the weight with you in the car?
makes me want to scratch my 351w plan, get rid of the bottle, and get that on3 kit. lol
H/C/I 302 + nitrous for now... supercharger/turbo soon?
www.youtube.com/Xarmy187
Please support my YouTube channel! My videos don't disappoint!
Old August 22nd, 2010, 11:15 PM   #16
fogged306's Avatar
89 GT
I dunno, if you got out and back in it and still had more MPH than your best run, I'd say that car has 9's in it for sure. Especially with a 1.8 60ft... but at the same time, you're right, if you keep pushing it, you're probably going to end up with some paperweights even if you don't turn up the boost.. That's still impressive for a stock bottom end though. Just more proof that it's not what you got, it's how you put it together.
Old August 22nd, 2010, 11:18 PM   #17
JBIGBOOTSY's Avatar
1990 LX hatch
90/10's 4cyl front springs. 50/50's some kind of progressive rate rear springs.
On our truck scale, with a fresh calibration(dont know how accurate at lower weight, they cal it with a 5k lb weighted tractor) it was 2960 with me in it, and 1860 was on the front tires.
Old August 22nd, 2010, 11:21 PM   #18
JBIGBOOTSY's Avatar
1990 LX hatch
the 1.8 60' was the 11.2, the 10.2 was a 1.67
I would love a 9.99, but I honestly think it will break.
Old August 22nd, 2010, 11:27 PM   #19
Burn'nRubber's Avatar
1992 Mustang GT
Coming soon...
Burn'nRubber is on a distinguished road
Congrats on the times, sounds like it runs great. Next time get it on video, I wanna see the bitch in action.
1992 Hatch: 306ci, gt40p's, comp xe270, Edelbrock Performer, 1.6 r/r, full bolt-ons, and some supension work
Old August 23rd, 2010, 12:31 AM   #20
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Didnt I say it would trap 127 lol. Congrats man. Glad to took it out and dusted it off.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Threads Similar to: new times.
new times bone_crusher 2005 - 2010 1 May 1st, 2010 11:43 PM
Going to get some 1/4 times jimmy toronto 2005 - 2010 7 March 23rd, 2010 07:45 PM
My new 0-60 Times :) 236Mustang Videos 12 September 26th, 2009 11:41 PM
I see my name so many times!!! supermachone The Clubhouse 28 March 7th, 2008 02:38 PM
Can 1/8th mile times give est 1/4th times? Nightstick Drag 3 April 16th, 2006 10:20 PM
