Ford SB Production Block Capability
Old March 30th, 2007, 06:06 AM   #1
Zak
Zak is on a distinguished road
So many people say the production block is capable to handle between 450 to 500 HP but is this a fact of a myth, and what can go wrong beyond that 500 HP rating?
If it's the main bearing caps, you can always use a billet steel main caps girdle to beef up the bottom end. or is there any other limitations..?
I get so jealous when I read that a small 6 banger Toyota Supra motor can handle 800 HP easy!
Old March 30th, 2007, 09:08 AM   #2
87foxbodylx's Avatar
1987 Mustang LX
13.9@102.43
87foxbodylx is on a distinguished road
I know some people that are pumpin out over 600rwp on a Small block. but its also forced induction.
And those small supra engines, are beastly little bastards. id take one in a heart beat.
Old March 30th, 2007, 02:39 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Re: Ford SB Production Block Capability
Are we talking a production 5 liter roller block? I've seen over 500hp many times with them. Hell, I've owned a few. A friend of mine is making 555hp at the wheels with a stock 93 short block. Eventually the block will fail at that horsepower level and the failure rate dramatically increases with rpm. Main caps aren't the issue. The issue is thin cylinder walls and week main webbing. A main girdle will hold the crank in when the block splits but that is about it. A steel main girdle might help with cap walk but will not prevent the block from splitting. There is nothing you can do to a production block to make it live at anything over 500hp. All you can do is pray.
Old March 30th, 2007, 06:32 PM   #4
Zak
Yes, I meant the production short roller block and that's all what I needed to know. Thank you so much indeed!
Old March 30th, 2007, 08:15 PM   #5
JBIGBOOTSY's Avatar
1990 LX hatch
supra engines are strong because they have 6 cy., and 6 main caps
Threads Similar to: Ford SB Production Block Capability
ford racing 351 crate engine to imitate a big block?? mplaczek Classic Mustangs 20 August 24th, 2007 10:26 AM
Ford 347 short block bob New Members Introductions 1 April 29th, 2007 01:51 PM
Production roller block @ 1100 HP Zak 5.0 Mustangs 10 April 24th, 2007 08:50 AM
What Is The Strongest Ford Block, OEM And Aftermarket? 99mustang232 The Clubhouse 2 September 2nd, 2006 11:04 PM
