93 LX 5.0 dies and wont start - Forums at Modded Mustangs
post #1 of 15 Old August 25th, 2010, 02:34 PM Thread Starter
I have a stock 93 LX 5.0 that recently has taken a nack to just dying on me, doesnt appear to be fuel, because it instantly quits with no sputtering (fuel), seems to be electrical. Once it dies, I pull off the road and crank it and sometimes it will start, and once it wouldnt start for a few days. I put a new clutch in a few months ago, but nothing electrical. Please send some help my way..........Regards, Woody
Woody45 is offline
post #2 of 15 Old August 25th, 2010, 02:51 PM
King of Clubhouse
Till's Avatar
Send a message via AIM to Till
Could your fuel pump just be dying?
Does it turn over like normal or a slow turn over?
Have you had your bat, alt, starter checked and what not (just incase)
Originally Posted by quickndslick2 View Post
^^go burn in a fire
Dumbass Club Founder
MM + Cleavage member #23
Till is offline
post #3 of 15 Old August 25th, 2010, 02:53 PM
PSN alphadong11
dr.gonzo!'s Avatar
Does it start right back up when it cools off?
Mine did this and every one said to change the ignition module
this thing
I changed that about 3 times and it still died when hot. Finally I changed the distributor and that fixed it. The pick up coil inside the distributor can go bad and I just bought an entire new distributor because I didn't want to mess with wiring the pick up coil in the distributor.
Not saying this is your problem, but seems to be a consistent problem in these cars.
dr.gonzo! is online now
post #4 of 15 Old August 25th, 2010, 03:17 PM Thread Starter
Not sure about starting when cooled off. Like I said the last time it died on me, it would not start and even after a few days, it still would not start. I had it towed to my house and I was able to start it to get it off the tow truck. While I am driving home from work, it dies, and I can either crank it til it starts or, pop the clutch while I am still coasting down the road. If I watch the tach, when the motor dies the tach dies too, like all electrical power is removed form the ignition. I had the alternator rebuilt a year ago, so I dont think that is it, the starter was out when I replaced the clutch two months ago. While coasting after the engine quits, the car cranks fine so I believe the battery has good volts. I seemed to get progressively worse, all occureing within a weeks time. Thanks for responses Doc Gonzo and Tiller, hope this helps. Woody
Woody45 is offline
post #5 of 15 Old August 25th, 2010, 03:25 PM
PSN alphadong11
dr.gonzo!'s Avatar
Yeah that does not sound like the problem I was having. Mine would always crank, just no start. I let it cool off for an hour and I would be good for 5 more miles and I would just keep repeating this step over and over.
post #6 of 15 Old August 25th, 2010, 03:29 PM
Priest of the Car Gods
ReverendDexter's Avatar
Okay, so you lose electrical when heat is introduced. That makes sense - something has bad conductivity already, and as conductivity goes down the hotter something is, the heat from running is just enough to put it over the edge.
First thing I'd check is all your ground connections. And I don't mean just visually inspect them, I mean take each one apart and clean it down to clean, bare metal with a wire brush.
Once you know your grounds are good, troubleshooting will be easier. Get out the multimeter and start checking resistances. You could have an almost-blown fuse or fusible link somewhere, you coil could be going bad (mine did that), coil wire, something in the dizzy... list goes on.
But definitely start with the easy/cheap things first, and cleaning those grounds is free.
Function > Form, always
ReverendDexter is offline
post #7 of 15 Old August 25th, 2010, 07:11 PM
voltage regulator could be going bad and shorting out or u have a bad ground and as the other guy said u need to do more then just look at them they should prob be cleaned
mustangproblem00 is offline
post #8 of 15 Old August 25th, 2010, 08:23 PM
FastStang91Lx's Avatar
this thing
My vote is TFI or pick up coil.... I would almost bet on it even not being there in person. TFI is the ignition module on the distributor pictured above.
FastStang's Ongoing projects thread Click here!
FastStang91Lx is offline
post #9 of 15 Old August 25th, 2010, 10:01 PM
PSN alphadong11
dr.gonzo!'s Avatar
Yeah but his does not even crank, even after it cools off, so I would think something is happening before it gets to the point of ignition. You can unplug the ignition control module and crank all day. Ask me how I know
post #10 of 15 Old August 25th, 2010, 10:35 PM
Whoops, when I went to quote you, I forgot to finish reading the thread....lol
Probably should pay attention.
post #11 of 15 Old August 26th, 2010, 07:34 AM Thread Starter
The motor cranks fine, just wont start, sorry for the confusion. I am going to replace both my positive and negative cables on my battery and then check all my grounds. Originally I was thinking it might be the coil, because it would only act up after the car had been running and got hot. But when I went to start it after it had been sitting all night and would not start I pretty much ruled that out. Woody
Woody45 is offline
post #12 of 15 Old August 26th, 2010, 01:18 PM
U try crancking it and spraying starting fluid? Also Check for power at the coil while crancking.
1fst5.0 is offline
post #13 of 15 Old August 26th, 2010, 03:29 PM
brimmer555's Avatar
Not sure its much help to ya but also check all the vacum lines. I had an Explorer that when I was driving it, it died out of nowhere and I looked under the hood and found that one of the vacum lines on the intake came off.
brimmer555 is offline
post #14 of 15 Old August 26th, 2010, 08:54 PM
You should still check to make sure you have spark leaving the coil. Just cuz it didn't start in the morning doesn't mean that it's not the coil. :facepalm
post #15 of 15 Old August 31st, 2010, 10:20 AM Thread Starter
Seems to be running ok
Thanks to all of you that replied to my post. I took the ignition module to the local parts store and ran it through the test 7 times trying to get it to fail. I got it good and hot but passed the test every time. I went ahead and replaced it anyway, just because. I have driven it to work for two days now and no problems, knock on wood. I still have a little miss every now and then, but if you were not looking for it you would not know it was there. I put new plugs in too, the others were a little worn. Again thanks to all that posted.
Regards, Woody
Woody45 is offline
Human Verification
