LinkBack (1) | Thread Tools |
#1
5.0 Stock Bottom End Strength
Hey guys, I was just curious if anyone knows how much the stock rotating assembly and block of a 5.0 can handle. I think I remember over 400rwhp is pushing it. What about rpm's? I have heard anything over 6,500 rpm's is too much strain on the motor. What do you think?
04 Stang 1.0Gallon V6
14.45 @95.8
are you talkin about a new 5.0..?
2004 Bolt on & Cammed 3.9L V6 |
1990 LX hatch
big torque, or big rpm, or any combo of the two. I've seen a 270hp motor split, and have heard of people getting up to 700, im sure it all depends on the condition of the motor.
I was refering to the fox body 5.0's. I was curious on the potential of the stock assembly w/o anything forged steel or modified.
ANGRY HILLBILLY
1969 Mustang Mach 1
SBF > LSx
Something was terribly wrong with a motor that split at 270hp.
![]() ^ .... ^ Me - LS1 driver
2004 Cobra
11.4 @ 129 - Need cage
500 RWHP max.
![]() NEW NUMBERS: 609/543 |
What about a max rpm that can be acheived safely w/o engine damage? Or simply put, what would be over-spinning it?
Depends...not a set number...
PeteAndersonRacing.com |
this may not be true, but i read that the engine can spin up to 6k safely, but the stock valves will start to float around 5k due to the weak factory springs. any truth to that?
'02 Mustang GTm Convertible - N/A Almost Cammed Daily - 13.55 @ 100.7 1.955 60' '88 Mustang GTm - 1/4 Mile Build - 750rwhp Project '97 Saturn SL2m - Ex-Nitrous Build - Back-Up Daily |
Not over-spinning it for hp or shift points, rather the highest rpm that can be acheived w/o causing damage or running a heavy risk of destroying a motor all together. Kind of like a "DO NOT GO PAST THIS ENGINE SPEED" rule of thumb. I know the Ford Racing X and Z cams make power up to 6,500 rpm's. Is that a bit too much for the stock rotating assembly? Again, I am just curious on how much these little shortblocks can handle.
1991 Mustang LX 5.0
Bad balance???
This is the most true statement... Every motor is different. I could say 500, but you could easily break at 4. I repeat... EVERY MOTOR IS DIFFERENT. The balance has a lot to do with it too.
FastStang's Ongoing projects thread Click here! |
Yeah, I agree. I know balance of the crank and condition of the engine play large roles in engine durability when racing. Still, if you had lets say, H/C/I on a well balanced motor that was running optimal with a strong valvetrain, would it be safe to take the stock bottom end components to 6,500 if the motor made peak power there? When is it a good time to upgrade the crank, rods, and pistons?
1989 LX coupe 5.0L
i beat on mine all day and its still going. first time ever to the track and i ran a best of 12.4 out of 3 passes and i make 296 to the wheels. ive also seen the tac go well above 6. mind you i dont care if this engine takes a shit
1991 Mustang LX 5.0
Stock rev limiter is 6250 rpms, so you don't have too much worry there. The only way to rectify that is with a chip removing it. Stock tachs are not accurate at all. I hit 6250 in my car when the tach says 7.
Yeah, I hear ya'. The stock tach. has a mind of it's own. Sometimes I have actually seen my needle hesitate when downshifting. So, does every fox body 5.0 have a built in rev limiter at 6,250? I have a MSD 6AL w/a 6,200 pill, so I have never seen it go off.
89 GT
Every EFI fox does. At 6250, the computer pulls fuel.
1989 LX coupe 5.0L
not going by the stock tach and the limiter is gone
#19 | |
1996 Cobra
Not fast enough.
Mods: Full 01 Cobra drivetrain (Teksid block ) T56, 3.73s, Pro 5.0, Aluminum driveshaft, JLT CAI, BBK O/R X, SLP LM1s, Full welded in sub frame connectors
1989 LX coupe 5.0L
i have an aftermarket tac and have spun it abouve but its not making and power
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/180648-5-0-stock-bottom-end-strength.html
| Thread 5.0 Stock Bottom End Strength | Forums at Modded Mustangs | BoardReader | This thread | Refback | November 10th, 2010 11:47 PM | |
Threads Similar to: 5.0 Stock Bottom End Strength
| Strength of Stock rear end w/ 3.73s | MyGT | 99-04 | 17 | November 4th, 2008 05:17 PM |
| 05+ vs 96-04 bottom end strength ? | Quicktime_GT | Modular Mustangs | 7 | December 26th, 2007 03:51 AM |
| How Much HP On Stock Bottom End | 5litercobra | 2.3 Mustangs | 5 | November 13th, 2007 02:55 PM |
| 12s with stock bottom end? | 95wip | 94-95 | 8 | April 16th, 2007 11:10 PM |
| How Much HP Can Stock GT Bottom End Take? | Clutchmaster | 99-04 | 14 | March 22nd, 2007 03:58 PM |
