hey, twist to go !
Old April 19th, 2006, 11:42 PM   #1
88stang's Avatar
1988 Mustang
88stang is on a distinguished road
hey, twist to go !
If the transmission stops are not adjusted properly, what are some symptons ? When I get on my car, it grinds going into 2nd and 3rd I thought it might be the synchronizers could it be maybe the stops are not adjusted properly.
Old April 20th, 2006, 08:21 AM   #2
if the stops are too loose, the syncro can overextend and possibly get stuck in gear. If they are adjusted too tight, the syncro doesn't fully engage the gear and can damage the gear teeth enough so that grinding and hard shifting occurs. Try loosening them up a turn or so and see if it gets better. Would also recommend draining the fluid and refilling w/ a good grade of ATF/Mercon trans fluid.
88 Mustang Coupe
www.rickscarcare.net
Old April 20th, 2006, 10:04 AM   #3
88stang's Avatar
1988 Mustang
thanks for the input
Threads Similar to: hey, twist to go !
A new twist on wife control WAR-PARTY The Clubhouse 3 November 2nd, 2007 01:58 PM
Ghost riding with a little twist..... C MY 4D Videos 4 July 21st, 2007 09:51 PM
Congrats to "Twist 2 Go" in 2nd place in FFW true IcantDo55 Drag 18 June 27th, 2006 01:51 PM
