92 Lx
Slow
93 cobra comp in a 92 lx?
would a 93 cobra comp fit in my 92 lx and if so would it even make a diff?
1991 mustang 5.0
why?
92 Lx
Slow
thought there comp would be more built then what my comp is
Yes it will make a difference. You will lose some horsepower. The X3Z Cobra computer timing curve is not as aggressive as the A9L an A9P units and also has a speed limiter. The reason for this was to detune the Cobra engine for drivetrain durability and warranty issues, or lack of warranty issues. The X3Z Cobra computer also has poor idle issues as well as hesitation issues associated with it. You will also need to run 24lb injectors because that is what the computer is calibrated for.
#5 | |
1993 MUSTANG GT
92 Lx
Slow
damn you guys are so helpfull. thanks for the help again
1992 mustang Lx
13.4@ 106
I have 24's and a 76 c&l mass air meter for 24's, and a cobra computer. I was planning on installing them all at the same time. Should I not even bother with the cobra comp?
![]() 1992 5.0 lx_soon to be powered by a m122 GT500 supercharger
89 GT
don't bother... with that meter tuned for 24's it will make things even worse because the cobra computer uses stock MAF electronics and "calibrates" for the injectors in it's fuel tables.Using that meter and a cobra computer will result in you spraying more fuel than needed.
1992 mustang Lx
13.4@ 106
okay thanks. I know one thing thats going on craigslist today.
1992 Lx
11.39@119.24
if you have a cobra maf to go with it you can get 300 bucks on ebay
#11 | |
Threads Similar to: 93 cobra comp in a 92 lx?
| 99 cobra comp cams dyno | 99cobra! | 4V / SVT | 33 | May 23rd, 2009 01:08 PM |
| TT Cobra Build Comp | JonnyB | Videos | 4 | May 1st, 2009 04:03 PM |
| BBR Stage 2, FRPP Hot Rod, Comp Stage 4 or Comp Thumper Cams | ivan48humble | 2005 - 2010 | 179 | December 8th, 2008 02:19 AM |
| i need some comp. help | weems | The Clubhouse | 16 | October 17th, 2007 09:45 AM |
