i need help removing these
Old March 31st, 2007, 05:11 AM   #1
1989 GT Hatch
YNOT is on a distinguished road
i'm trying to replace the thermostat, waterpump gasket, and timing cover gasket.
i have the radiator and fan out, water pump off, but i can't get the thermostat housing off because i can't reach the bolt.....the distributor is in the way and i don't know how to take the distributor off to get to that bolt.
also do i need a special puller to get that lower pulley off so i can get the timing cover off to replace that gasket?
Old March 31st, 2007, 09:54 AM   #2
1993 Mustang GT
Haggis13 is on a distinguished road
Send a message via MSN to Haggis13
Get creative - thermostat cover will come off without removing the distributor.
I've only ever used a pulley remover tool when I worked on the crank pulley, but that's just because my father has one. Makes it real easy to get off.
Bart
93 Black on Black GT
Kenne Bell S/C
GIVE 'ER!
Old March 31st, 2007, 11:28 AM   #3
1989 GT Hatch
both the distributor and timing cover are in the way to get to that lower thermostat bolt.
Old March 31st, 2007, 01:04 PM   #4
foxstang is on a distinguished road
i can take my thermostat housing off without removing anything. like haggis said "get creative"
89' 306 W/ Edelbrock performer 5.0 heads, BBK SSI intake, F-303 cam, 75mm MAF, 75mm TB, 30lb injectors, 255lph fuel pump, BBK afpr, BBK shorty headers, Off road X-Pipe, Flowbastards, and 3.73 gears.
Old March 31st, 2007, 09:43 PM   #5
83 5.0's Avatar
83 5.0 is on a distinguished road
I have a box end wrench that gets around everything, nothing special, you just don't get a lot of turn out of it, but it gets it off.
Old March 31st, 2007, 10:07 PM   #6
homebrewed's Avatar
'88 LX body '91 GT D/T
8.7 in the 1/8th
homebrewed is on a distinguished road
I coulda used that for my wife when I was married lol
As for the removing of stuff, look at from other angles.
Take the repair manual, turn to the page(s) outlining your repair, tear the shit outta 'em and start a fire. Then, have your neighbor come over and take a look at it.
Founder of the I don't like my shit centerd and want it back the way it was dammit! club
www.myspace.com/evoalliance
greatest band alive
Originally Posted by Tony_90fox View Post
I wish there was a :lickmynuts smiley, because i would use it now
:lickmynuts
Old March 31st, 2007, 10:17 PM   #7
1993 Mustang GT
Yeah - I don't get it. I even went out and looked just to see if I was losing it, but there they are (the nuts) clear as they've ever been. Attack from all angles!!
Bart
Kenne Bell S/C
GIVE 'ER!
Old April 1st, 2007, 04:24 PM   #8
1989 GT Hatch
yeah i figured i didn't need to remove the distributor. now i'm trying to get the timing cover off, but it's stuck and i have all the oil pan bolts out.
Old April 1st, 2007, 04:26 PM   #9
1989 GT Hatch
quick question am i stupid to not change the timing chian while i'm in there? i'm just trying to change that gasket.
Old April 1st, 2007, 04:28 PM   #10
homebrewed's Avatar
8.7 in the 1/8th
If its only a matter of a few more nuts and bolts, do it. Its gonna need to be changed eventually. You're already there...
greatest band alive
:lickmynuts
Old April 1st, 2007, 04:30 PM   #11
1989 GT Hatch
can i just get one from pep boys, napa, o'riely, checker, or autozone?
Old April 1st, 2007, 04:36 PM   #12
homebrewed's Avatar
8.7 in the 1/8th
You betcha...
If ya got an Advance Auto Parts, they offer a ZOOM brand. Its an upgraded unit over the OE type. Double roller design. I am sure that the other stores offer something similiar. I used to work for AAP and know what they sell. The SA Gear brand they (Advance) sells offers a Lifetime Warranty.
greatest band alive
:lickmynuts
Old April 1st, 2007, 07:53 PM   #13
1989 GT Hatch
I'll just order a timing chain and gear set, any brand you recommend or any double roller design?
Old April 2nd, 2007, 01:33 AM   #14
1989 GT Hatch
How do you rotate the camshaft so I can remove the chain and gears?
Threads Similar to: i need help removing these
Removing a decal what is the best way 05stang808 Visual 3 May 28th, 2007 08:59 PM
Removing the honeycomb Juggalo_X V6 Mustangs 24 May 3rd, 2007 12:00 PM
Removing air silencer ? Hudstang 96-98 4 April 20th, 2007 12:04 AM
Removing Air Bag ? 92lx5oh 5.0 Mustangs 3 April 10th, 2007 10:19 PM
Removing Old A/C CR70fastback Classic Mustangs 7 January 18th, 2007 06:19 PM
