Rear end issue
Old August 30th, 2010, 08:24 PM   #1
1995 Mustang GT
vindi is on a distinguished road
Send a message via AIM to vindi
Rear end issue
So when I got the car somebody had put 4.10 gears in it and it howls at cruise speed say pulling a hill or in a high gear 4th or 5th and low rpm around 2k. With the car on jack stands you can feel a good bit of play while turning the driveshaft in the rear end. Maybe around 1/4 inch. Other than that it sounds fine coasting and standing on the throttle
I am pulling it apart because the pinion seal is leaking, but I have never let run out of fluid. Do you guys think the backlash is off? I was thinking about just trying to set that, installing new seals and crush sleeve and roll with it or do I need to replace everything.
Threads Similar to: Rear end issue
8.8' Rear end vs. 9" rear end jhooper Classic Mustangs 22 April 25th, 2011 03:59 PM
Rear End / Rear Wheels problems caliboss281 99-04 21 January 28th, 2009 04:52 PM
rear disk brakes and rear end extropy Classic Mustangs 3 August 11th, 2008 06:41 PM
7.5 rear end issue JasonMarshall V6 Mustangs 13 April 22nd, 2008 07:53 PM
