Stumbling problem part 2... - Page 2
Old September 3rd, 2010, 12:21 AM   #21
'88 Mustang GT
DigitalDC89 is on a distinguished road
Send a message via AIM to DigitalDC89
both actually. the temp sensor for the gauge does NOTHING for the computer, and is only for the drivers sake.
the coolant temp sensor is in the heater tubes, and is for the computer, as is the air intake temp sensor on the lower intake manifold. both of which can cause issues if they are bad.
'02 Mustang GTm Convertible - N/A Cammed Daily
'88 Mustang GTm - 1/4 Mile Build - 750rwhp Project
'97 Saturn SL2m - Ex-Nitrous Build - Back-Up Daily
Old September 3rd, 2010, 12:26 AM   #22
1NVERTED5.0 is on a distinguished road
Originally Posted by WhiteMamba View Post
I feel like that must be it too...where are all the vaccum lines that I should check...keep in mind I have an EGR delete.
i mean just by you saying you can hear an air noise when you brake makes me think start with your brake booster line on the firewall drivers side it'll say B/B with a hose leading to it and to the brake master cylinder.
My moneys on one of the vacuum hoses if not that one having a massive fucking leak in it.
1990 Mustang 5.0 Vert'
2009 Nissan GTR
Old September 3rd, 2010, 07:04 AM   #23
FastStang91Lx's Avatar
1991 Mustang LX 5.0
This is the one I have NOT replaced...is that the one you suggest?
Advance Auto Parts: Coolant Temperature Sensor by BWD - Part WT5058Z
Link works now.... Yep, that's the one. Like said earlier... I'd replace the air temp sensor too, just for piece of mind. Cheap, but yeah I know, it all adds up.
SIDE NOTE: Also when you go to check voltage on your TPS when you do the base idle reset, check your full sweep from closed to open to make sure the voltage escalates at a constant rate. My buddies was in the parameters at closed, in the parameters open, but jumped all over in the middle. Just open is kinda slow and smoothly, and the voltage should progressively get higher.
Old September 3rd, 2010, 07:59 AM   #24
WhiteMamba's Avatar
88 Notch
WhiteMamba is on a distinguished road
HOLY SHIT...I may have found the problem...
The vaccum line coming out of the tree labeled S (last one on tree toward passenger side of car) that runs to the back of the motor is ROTTEN!!!
It's dry, cracked and definetly not a good line.
Tell me this could be it???
What does the S stand for on the tree. Going to Advance to pick up those sensors and pick up a new vaccum line as well.
Old September 3rd, 2010, 10:14 AM   #25
'88 Mustang GT
its the 'Source' line coming from the intake manifold. if its all cracked, it could be a nice leak.
EDIT: hopefully the sensors and a new vacuum line get it running good again
Old September 3rd, 2010, 01:28 PM   #26
WhiteMamba's Avatar
88 Notch
I replaced everything (2 sensors, vaccum line for the SOURCE) and set my tps. TPS was reading 81-82.
The car is definetly running ALOT better but I am still getting the stumble. It happens very inconsistently and I do not have the time to check anything else.
Off she goes to get the turbo...
Hopefully the MSD 6AL, New injectors or new MAF that come with the kit do the trick.
On a sidenote the car is running MUCH better when cooler. I definetly fixed a few things today just not quite the major issue yet.
Thanks for all the help!
Could it be the fuel pump relay acting goofy?
I did the vacuum test as well....
it read 17-17.5 at idle which means normal according to the chart.
Old September 3rd, 2010, 11:16 PM   #27
'88 Mustang GT
in your other thread, you said you had new oxygen sensors but you didnt install them yet, correct? they might be the problem. when you accelerate, the old sensors might not switch fast enough, causing a lean condition, aka the stumble, which then goes away when the sensors catch up. couldnt hurt to replace them atleast.
Old September 3rd, 2010, 11:37 PM   #28
WhiteMamba's Avatar
88 Notch
I was able to get one in...the other was so dam tight I could not get it to budge. The guy installing the turbo will do the other this weekend.
Old September 4th, 2010, 12:59 AM   #29
'88 Mustang GT
what i did to remove it, make it simple.
get a hammer.
break neck of sensor off.
find a suitable socket.
using either a breaker bar, or impact gun, remove old sensor.
install new.
win.
Old September 4th, 2010, 04:36 PM   #30
WhiteMamba's Avatar
88 Notch
Stopped by to watch turbo install today...
All kinds of vaccum leaks that were not found! On the bottom of the manifold the two nipples had one completly rotten rubbe plug, the other was hard and old.
PCV valve hose leaking all over....
Spark plugs were all very lean.
A few of the fuel injectors had flat o-rings and one even had a little rust from water on it...
The saga continues! But hopefully once she is buttoned up with all this new equipment all the problems will be gone!
Massive intake manifold gasket leak as well. It's amazing what you find when you did down into the head of the motor! LOL!
Old September 4th, 2010, 08:08 PM   #31
fogged306's Avatar
89 GT
With all those vacuum leaks that car idled with a solid 17" of vacuum at idle?
Old September 4th, 2010, 08:20 PM   #32
WhiteMamba's Avatar
88 Notch
It read 17-17.5. I never tested to see if it went up or down with throttle.
Threads Similar to: Stumbling problem part 2...
stumbling up top Blackblurr_00GT 99-04 21 February 18th, 2010 04:53 PM
The Muschallaro: Part Challenger, Part Camaro, Part Mustang marq.fcb The Clubhouse 27 December 24th, 2009 01:36 AM
Stumbling on acceleration lowp51 94-95 4 March 14th, 2009 10:13 AM
86 stumbling under load hopper 5.0 Mustangs 6 April 25th, 2007 09:25 PM
stumbling in hawxter996 V6 Mustangs 20 March 6th, 2007 09:51 PM
