88 Notch
Stumbling problem part 2...
As some of you have read my car was having a misfire issue spontaneously. Some days I thought i might have even fixed it but the son of a bitch is still here.
My turbo kit goes on this weekend and I need to give this one more shot. The good and bad news is that the problem is getting worse the last few days. When the car is cold it barely runs and misses bad all over the place. Once it warms up it seems to clear but still runs rough at part throttle and seems good at WOT but has an occasional miss at WOT. Sometimes the idle is smooth but the last few days it has been hunting a little bit. Codes it is throwing are all EGR related (and my EGR has been deleted) I have replaced the following: Spark Plugs/Wires Ignition Coil IAC Ignition Module 02 sensors Checked grounds (as best I could) The turbo kit comes with 44lb injectors and calibrated MAF. The car will also get a MSD 6AL at this time. I'm hoping one of those turbo components will fix my issue. What are the odds of it being the distibutor or PCM? Could it be the TPS? Anybody have any thoughts before the turbo goes on? Thanks! |
89 GT
Do you have a vacuum gauge? I would check your vacuum at idle.
88 Notch
89 GT
Just pull a vac line off the tree for something like your heat controls or your cruise and hook up the vac gauge to that.
Courtesy of Joel
88 Notch
88 Notch
Do I let the motor get to normal temp first?
1991 Mustang LX 5.0
Air temp sensor on the intake runner, and coolant temp sensor for the ecu, not the gauge. The one in the heater tube. Without reading your other thread, I assume you did the base idle reset, and all that jazz?
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 Last edited by FastStang91Lx; September 2nd, 2010 at 11:23 PM. |
88 Notch
89 GT
It's a sticky in this section.
1988 Mustang GT
its a sticky in this forum....
edit - dammit too slow! |
88 Notch
I will try the idle reset as well tomorro...
Just to clarify... I connect the vaccum gauge to the air temp sensor once the car is fully warm up? Or do I connect it to the tree? |
88 Notch
Another thing I have noticed is that I hear an air sound when I pump my brake coming from the pedal...is that normal?
I have read there is a vaccum down there but would that cause my problem? |
1991 Mustang LX 5.0
No... to the tree. I was suggesting sensors to replace... Sorry, I should of quoted to make it clear.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
88 Notch
any part of the tree? thanks...I will replace those two sensors as well. I already replaced the sensor that control the temp on the coolant gauge...the one with the rubber elbow plug...
88 Notch
This is the one I have NOT replaced...is that the one you suggest?
1991 Mustang LX 5.0
Under construction???
you probably have a massive vacuum leak.
1990 Mustang 5.0 Vert' 2009 Nissan GTR
88 Notch
that sensor can cause issues as well. if its OEM, its probably worth replacing anyway.
check the vacuum tree for starters. then head to the passenger fender well where the EGR vacuum lines and solenoids were/are. maybe you left one open?
'02 Mustang GTm Convertible - N/A Cammed Daily '88 Mustang GTm - 1/4 Mile Build - 750rwhp Project '97 Saturn SL2m - Ex-Nitrous Build - Back-Up Daily |
88 Notch
the air temp or the coolant sensor?
Threads Similar to: Stumbling problem part 2...
| stumbling up top | Blackblurr_00GT | 99-04 | 21 | February 18th, 2010 04:53 PM |
| The Muschallaro: Part Challenger, Part Camaro, Part Mustang | marq.fcb | The Clubhouse | 27 | December 24th, 2009 01:36 AM |
| Stumbling on acceleration | lowp51 | 94-95 | 4 | March 14th, 2009 10:13 AM |
| 86 stumbling under load | hopper | 5.0 Mustangs | 6 | April 25th, 2007 09:25 PM |
| stumbling in | hawxter996 | V6 Mustangs | 20 | March 6th, 2007 09:51 PM |
