LinkBack (1) | Thread Tools |
#1
86 Mustang GT
Throttle body/ egr spacer question
Just bought an 86 5.0 less than a month ago. I've never been a big car guy until I purchased her. So I will probably have a lot of questions that seem basic to the average mustang guru. I want to order a throttle body/ egr spacer and they come in sizes from 65 mm like up 105mm. Which one would fit in mine?
89 GT
What intake is on the car? What are your plans for the car?
86 Mustang GT
Well my plans for the car are to replace everything that's crapper out. The guy I bought it from kind of did the bare minimum to keep the wheels rolling. Like I said I honestly know little about cars but I'm doing my best to learn. As far as the exhaust I believe it's the stock manifold.
#4 | |
1991 Ford Mustang GT
And do you plan on sticking with the stock air intake manifold or go with a bigger better flowing one.Do you plan on changing your heads, exhaust ect... need to know these things in order to tell you what size TB and EGR would be best for your app
86 Mustang GT
As far as the intake manifold just looks like your basic manifold nothing impressive. I'd eventually like to get a trickflow or cobra intake manifold ... Or whatever someone else suggests. Should I just hold off and wait? I wish I could upload a pic but I'm having to do this all off an iPhone due to Internet in Germany
I read some where that if your going to leave every thing stock then a 65mm TB is good. If you plan on just changing your air intake then also a 65mm TB is good. And if your going to go with a bigger cam and aftermarket heads along with the air intake maifold then 70mm TB is good. And if after all that you plan on using a power adder such as a supercharger then go with 75mm TB and above. WHAT DO THE REST OF YOU GUYS THINK ? IS THAT A GOOD RULE TO GO BY ? OR NO ?
86 Mustang GT
Right now I've got bbk headers.... Old and rusted. Going to be replaced. I'm satisfied with the intake manifold for now I just didn't know which would fit bc of the size of the hose going to the cold air intake... Which will also be replaced.
86 Mustang GT
Gotcha heads.... Not headers... Mulligan
#10 | |
1991 Mustang LX 5.0
But if it were me, I wouldn't buy any until I changed the intake. The tiny little bit that you could see from a throttle body swap is not worth buying a throttle body twice. If you go with a TF intake, you're looking at a 75mm opening; cobra is 70mm. And you don't want to put a bigger tb on than the opening or you will have a nasty lip that will screw up the air flow. The reason that I know this is because I have a 65mm, a 70mm and the current one on my car now - a 75mm.
FastStang's Ongoing projects thread Click here! |
86 Mustang GT
Thanks for everyone that helped me out w this. This really is addictive bc now I'm sitting here trying to figure out what else to throw into my 86.
Don't bother with a throttle body on the stock 86 intake. If I remember correctly the throttle opening on the intake is 58mm. Putting a bigger throttle body on a poor flowing intake is a waste.
86 Mustang GT
I did end up ordering it before I read final post. I'll throw it on there and if all else fails I'll just take it off.
go to corral.net and check out the classifides section.. find an intake for much cheaper and bolt that new fresh throttle body on to that bitch.
an engine is a huge air pump so you want to get the air in with least amount of resistance as possible and the same goes with getting the spent air/fuel out of the motor with that said the biggest restrictions on your motor is the stock heads and stock intake manifold. So set your goals and then ask all the questions you can think of to get you to that goal with the car before spending any money and you'll be buying parts once rather then buying shit then having to rebuy a better or correct part |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/181980-throttle-body-egr-spacer-question.html
| Thread Throttle body/ egr spacer question | Forums at Modded Mustangs | BoardReader | This thread | Refback | March 24th, 2012 05:30 AM | |
Threads Similar to: Throttle body/ egr spacer question
| Throttle Body + Spacer question | FortMustanger | V6 Mustangs | 11 | May 21st, 2010 01:10 PM |
| Throttle body spacer question | metallicat | 2005 - 2010 V6 | 9 | January 15th, 2009 05:27 PM |
| egr spacer with bigger throttle body | fastford3388 | 5.0 Mustangs | 6 | July 9th, 2008 08:20 PM |
| throttle body spacer | JASonic | The Clubhouse | 11 | July 18th, 2007 08:46 PM |
| Throttle Body Spacer Question | cobraetti | 5.0 Mustangs | 15 | November 1st, 2006 04:32 PM |
