12.37@105.63
93 5.0 and bad issues need help fast!
I have a 93 bronco with 5.0 I figured id ask on here since I post here on my 04gt. Problems I'm having I accidently sucked some water in motor and had to drive it home I changed oil from 10 30 to 20 50 and engine restore. Starts up and has oil pressure then loses it completely. Also I'm getting white smoke out of exhaust and around the head and overheating pretty quick. It's been smoking a while thought it was blue before I changed like now just white but it idels fine then a little gas hesitates then smooths out. Idk what to do im not familar with these motors. Please say its an easy fix I'm thinking just cracked head or blown head gasket.
04 GT 5-Speed, Underdrive Pullys, Mac CAI, Flowmaster 10's, 75mm intake and plenum, O/R X-Pipe, SCT Programmed, 18" bullit rims. |
1991 Mustang LX 5.0
Nope... your thinking is spot on... You damaged her. Time to pull the heads and have them checked. As far as sucking the water in.... water doesn't compress, so hopefully nothing in the rotating assembly is fugged.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
12.37@105.63
I think its possibly a broke ring blowing blue smoke out of breather tube and dip stick hole now
89 GT
Leakdown test will help pinpoint that. You may have both if you have white smoke out the tailpipe and blue smoke out your breathers and dipstick tube.
1984 Mustang LX
check for continuity at your oil pressure switch
Threads Similar to: 93 5.0 and bad issues need help fast!
| Headlight issues (in a bind - need help fast) | Invictus | 99-04 | 22 | August 17th, 2010 07:10 PM |
| Bad bad bad day!!! wrecked my car. :( | c10_87 | 99-04 | 7 | May 12th, 2010 01:08 AM |
| Need help bad...returnless fuel issues | JTs03v6 | General Tech | 4 | October 20th, 2009 03:05 PM |
| Alignment issues bad | mantis3567 | 99-04 | 21 | January 7th, 2009 11:09 PM |
