blown head gasket?
Old September 4th, 2010, 11:44 PM   #1
91cobra5.0's Avatar
98 Cobra
blown head gasket?
Ok so now that I've got one problem fixed now I've got another, my car started running hot and I did completely burp the system and now I am constantly needing to put more coolant in it or else it runs wayyyyy to hot, and now today I've started blowing smoke out of the passener side tailpipe, it smells almost like coolant out of the tail pipe too. So wt do u guys think? Blown head gasket?
Old September 5th, 2010, 12:07 AM   #2
fogged306's Avatar
89 GT
If you didn't do the lower intake gasket right, it can dump coolant into the cylinders. If that's what you replaced, it's a pretty good bet that's where the problem is.
Old September 5th, 2010, 12:09 AM   #3
91cobra5.0's Avatar
98 Cobra
What could I have done wrong? I used the right stuff around the coolant ports and put new gaskets down.
Old September 5th, 2010, 12:18 AM   #4
1992 Lx
11.39@119.24
Pull it and do it again
Old September 5th, 2010, 12:18 AM   #5
fogged306's Avatar
89 GT
There could be a few things. I don't know for sure on these cars because I haven't done one wrong yet, but in general you can put them in upside down, torque the bolts too much, not torque them enough, not align them properly.. I'm sure there's a couple more reasons. I had one blow open like your old ones and it dumped coolant into the cylinder and smoked like a head gasket, but this was on a chevy pickup and not a 302 so I can't really give you specifics. Maybe someone who has more experience with this on a 302 can chime in.
Also not saying that's your issue for sure, but it seems a likely suspect considering that you just replaced them. That would be a pretty good coincidence that your head gasket would go right after you put new intake gaskets on.
Old September 5th, 2010, 12:25 AM   #6
91cobra5.0's Avatar
98 Cobra
Damn looks like I'm tearing em out again
Old September 5th, 2010, 12:42 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Are there bubbles in the radiator when the engine is warmed up?
Old September 5th, 2010, 05:48 PM   #8
91cobra5.0's Avatar
98 Cobra
No I burped the system more than once, I jacked the front of the car up, took the cap off the radiator and let it run and filled it as it went until it stopped with the bubbles and was just spilling coolant out of the radiator
Old September 5th, 2010, 05:53 PM   #9
candcperformance's Avatar
candcperformance is on a distinguished road
check your plugs they will tell you what each cylinder is doing, if it has coolant on it you will see it, just my o2 i just do this for a living
Old September 5th, 2010, 06:06 PM   #10
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
Even if you did burp it at first, if there is a blown gasket letting air in it may be letting some bubbles in it. You could also have a leak at the EGR block where the coolant passes through.
if you do a lower intake gasket install, do yourself a favor and do not use the 2 short gaskets that come with the kit. Instead lay a nice bead of RTV silicone in place of it.
Threads Similar to: blown head gasket?
Blown head gasket? PVC blown off Stangin94GT 5.0 Mustangs 6 July 21st, 2010 10:15 AM
Blown Head Gasket saltydog_NM 5.0 Mustangs 8 August 28th, 2008 04:01 PM
=( blown head gasket itschristorres8 V6 Mustangs 17 October 23rd, 2007 11:14 AM
blown head gasket 5.0pwr 96-98 2 September 17th, 2007 11:57 PM
Blown Head Gasket Lax89 5.0 Mustangs 10 February 17th, 2007 08:01 AM
