4.10 install
Old September 4th, 2010, 11:54 PM   #1
'88 Mustang GT
DigitalDC89 is on a distinguished road
Send a message via AIM to DigitalDC89
4.10 install
i searched and couldnt find what i was looking for, so i apologize if this has been asked previously.
my friends dad is going to help me install 4.10's in my 88 GT, along with new bearings, and a rebuilt trac-lok. i bought a FRPP gear set, FRPP Carbon Fiber rebuild kit, and a Motive Bearing/Installation kit all from American Muscle. i have all the parts i need, just locating some tools, and i think all i need to pick up is a 0-100in/lb torque wrench to set the preload and some loctite, but heres my question.
i rented a 2/3 Jaw Puller from autozone to remove the bearing flange from the pinion. can we use that to remove the old bearings, or must i locate a bearing puller? if so, could somebody give me a link to the proper tool to buy/rent? thanks
'02 Mustang GTm Convertible - N/A Cammed Daily
'88 Mustang GTm - 1/4 Mile Build - 750rwhp Project
'97 Saturn SL2m - Ex-Nitrous Build - Back-Up Daily
Old September 5th, 2010, 12:11 AM   #2
fogged306's Avatar
89 GT
Did you read through the sticky "trac lok rebuild" in this section? I'm not sure if he covered your question or not, but it's a good thread to read if you're doing a gear swap.
Old September 5th, 2010, 12:27 AM   #3
'88 Mustang GT
i read thru it a few times for reference. my friends dad knows exactly what to do, so ill just be helping. but the how-to doesnt say anything about the bearings.
Old September 5th, 2010, 12:41 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Good luck with that puller to get the bearing off of the pinion. Do you have a press to install the bearing on the new pinion?
Old September 5th, 2010, 04:12 PM   #5
'88 Mustang GT
i picked up a bearing separator today at Harbor Freight. were going to use that, along with the puller to get the old one off.
we dont have a press to get the new bearing on, but i remember watching a show on Spike's Powerblock on Sunday morning, and a simple way to get the bearing on, without a press, is to simply heat it up and drop it onto the pinion. the heat should expand the bearing enough to let it slide into place.
Old September 5th, 2010, 04:19 PM   #6
Just did this.. put new pinion in freezer and bearing in the oven...
PeteAndersonRacing.com
Old September 5th, 2010, 04:29 PM   #7
'88 Mustang GT
thats an excellent idea actually. did you have to hit it down at all, or did it slide all the way into place? were doing this tuesday night, so i want to have it all prepared
Old September 5th, 2010, 04:38 PM   #8
It just fell right on tap it down to make sure it flush..I dont know if the bearing seperator will work from harbor freight.. i tried it and it just ripped the cage off.. i did yesterday use a trick pinion bearing seperator tool.. not cost affective for one timers tho..
Old September 5th, 2010, 05:05 PM   #9
'88 Mustang GT
i think 1slo5.0 is right. the jaw puller i have wont reach far enough to grab onto the bearing separator to pull it off. ill have to return it, and buy one with a longer reach.
Threads Similar to: 4.10 install
S/C Install CJam3 General Tech 4 June 22nd, 2009 03:28 PM
install done SWEET2KSTANG Pictures 29 June 10th, 2009 10:51 AM
install Jucostud 2005 - 2010 41 March 6th, 2009 06:46 AM
install ? 00redgt Visual 8 March 25th, 2008 10:19 PM
L/T install? MyGT 99-04 7 January 19th, 2008 10:53 AM
