Temp Gauge Issues
Old September 5th, 2010, 12:07 AM   #1
banks90gt is on a distinguished road
Temp Gauge Issues
ok so here where it starts....my car off with no key in the ignition and when i turn my light switch on my temp gauge goes up....ok then i put my key in and turn it to on...the temp goes back down and reads whatever the temp is....ok so heres the problem.....when im driving and say im down shifting s my rpms go down my temp gauge goes up and my battery light wll flash n go away.....my thermostat is new water pump and alternator are relatively new
Old September 5th, 2010, 12:13 AM   #2
'88 Mustang GT
DigitalDC89 is on a distinguished road
Send a message via AIM to DigitalDC89
sounds like a loose belt to me. the increase in engine speed causes the belt to slip, reducing the coolant flow and alternator output.
'02 Mustang GTm Convertible - N/A Cammed Daily
'88 Mustang GTm - 1/4 Mile Build - 750rwhp Project
'97 Saturn SL2m - Ex-Nitrous Build - Back-Up Daily
Old September 5th, 2010, 12:18 AM   #3
if it was the belt then y is my gauge trippen when the light switch is on
Old September 5th, 2010, 12:22 AM   #4
'88 Mustang GT
the gauge is electrical. the lower voltage is probably messing up the sender.
Old September 5th, 2010, 01:08 AM   #5
fogged306's Avatar
89 GT
Has this always been an issue or did it start out of nowhere?
Old September 5th, 2010, 01:19 AM   #6
ryanw's Avatar
1991 Ford Mustang GT
Im not sure if this is the problem but i had a problem with my fuel gauge and it turned out to be the anti slosh circuit board that plugs into the back of the gauge cluster. its on the top of the cluster in the back on the same side as the fuel gauge. but its also a volt regulator for you gauges. there like $80 new at latemodelresto.com or you can get them cheaper at a junk yard. ( but i think there only on 1990-1993 mustangs)
Old September 5th, 2010, 02:19 AM   #7
it just started the other day......im lost
Old September 5th, 2010, 02:29 AM   #8
ryanw's Avatar
This is what that voltage regulator looks like. This is a replacement voltage regulator panel for your 1990-93 Mustang instrument cluster. This panel regulates the amount of voltage to your gauges and keeps them functioning properly. If you have had problems with jumpy needles, mis-readings, or flickering lights on your dash panel gauges, this could be the culprit!
1990-93 Mustang Instrument Voltage Regulator by Ford at LRS - Same Day Shipping!
Threads Similar to: Temp Gauge Issues
temp gauge MustGT98allday 96-98 3 August 21st, 2010 11:43 AM
temp gauge stage2ROUSH 2005 - 2010 12 January 13th, 2010 04:57 PM
Coolant Temp Sensor issues 1sick94hb 5.0 Mustangs 0 April 24th, 2008 03:43 PM
new temp gauge burnout5.0 94-95 3 July 6th, 2007 04:10 AM
Temp Gauge Help 5.0 5.0 Mustangs 21 April 7th, 2007 05:22 PM
