grinding noise in trans?
Old September 8th, 2010, 02:09 AM   #1
92ponylx's Avatar
92 Lx
Slow
92ponylx is on a distinguished road
ok not sure what the noise is i think it may be a throw out bearing but not sure. while im stopped and i have the car out of gear i hear a metal to metal noise. as soon as i put my clutch in you can hear it slow down and go away... any ideas?
Old September 8th, 2010, 02:32 AM   #2
bustang's Avatar
88 LX hatch
bustang is on a distinguished road
My computer is being slow, so if this answer has already been posted, don't kill me. But that same thing happened to my truck in July 09. I ended up having a bearing race that melted and trashed my trans. Had to replace the trans, master & slave cylinder, and clutch.
A-Rod
Mr. April/Miss October
Old September 9th, 2010, 12:31 AM   #3
1992 Mustang LX
Somewhere in the 12's...
StangBanger302 is on a distinguished road
My throwout bearing was bad and it sounded more like a whirring noise than metal-metal..
New combo coming this spring...Dart Pro 1 heads, custom Bret Bauer billet HR, port matched Super Victor EFI, 30# injectors, 1 3/4 headers with 3" collectors, 3 inch exhaust to tailpipes, 4.10s a 175 shot and all behind a Tremec 3550
Old September 9th, 2010, 01:41 AM   #4
92ponylx's Avatar
92 Lx
Slow
that whirring noise is what it sounds like. it was just hard to describe. like you can tell that its rotating as its gringing... how much was it to fix it?
Old September 9th, 2010, 01:44 AM   #5
1992 Mustang LX
Ford Racing M-7548-A - Ford Racing Throwout Bearings - Overview - SummitRacing.com that is just a FORD one. Centerforce makes one too...up to you and your preferences.
Old September 9th, 2010, 02:04 AM   #6
92ponylx's Avatar
92 Lx
Slow
how big of a pain was it to replace?
Old September 9th, 2010, 02:11 AM   #7
rocks in tranny?
PeteAndersonRacing.com
Old September 9th, 2010, 10:05 AM   #8
bustang's Avatar
88 LX hatch
If it's just the throwout bearing...you'll still have to pull the trans and pull the throwout bearing off the input shaft. I've never replaced one on a ford, but on toyota's, they're a pita. If it's inside the trans, you may as well just take it to a shop to have it re-built or replaced. When you drive it, does it make noise in 1 or 2 specific gears, or in every gear?
A-Rod
Old September 9th, 2010, 06:26 PM   #9
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Pull the trans off the bell housing and then you'll see the throwout bearing riding in the middle of the shift fork. Cake!
A whole bunch of crap that makes the car go fast
Old September 10th, 2010, 01:37 AM   #10
92ponylx's Avatar
92 Lx
Slow
the only time it makes the noise is out of gear just standin still. as soon as i put the clutch in the sound goes away. so i have no effin clue.
Old September 10th, 2010, 04:01 AM   #11
1988 Mustang 5.0 LX
12.48@118.27
ddarkslayer is on a distinguished road
my throw out bearing sounds like crickets chirping
Old September 10th, 2010, 04:20 AM   #12
bustang's Avatar
88 LX hatch
Sounds to me that it's just the throwout bearing. You'll still have to drop the transmission to replace it. It's on the input shaft of the trans and held in place by, I can't remember the name, but it looks like a fork. You have to remove that fork, pull the bearing off, replace the bearing, and line it back up with the fork again. Then secure the fork in place....re-install the trans and you should be good. If you know you can't do it at home, just take it to a shop and save yourself the headache. The cost will depend on the shops labor rate and the cost of the bearing.
If I'm wrong or left anything out, please, someone add to or correct me.
A-Rod
Old September 10th, 2010, 01:35 PM   #13
92ponylx's Avatar
92 Lx
Slow
can you eff up anything by drivin around on a bad throw out bearing?
Old September 10th, 2010, 03:19 PM   #14
Digsj7's Avatar
1993 Mustang LX
my dog runs faster...
Digsj7 will become famous soon enough
You can drive it all you want...until you end up on the side of the road. Eventually it will go out and leave you stuck wherever you are. Pull the tranny and replace it.
CAI, GT40 Intake, GT40P heads, 1.72 RR, 70mm Accufab, UPR Control arms, Hedman Headers, Mac H-Pipe, Flows, Pro-5.0, 3.73 Gears, BBK caster/camber kit, Eibach springs, Subframe Connectors, 5 lug conversion,
MM+Cleavage Club Member #19
Old September 11th, 2010, 05:25 PM   #15
92ponylx's Avatar
92 Lx
Slow
Is it possible the throw out bearing could just be bad and the clutch still be good?
Old September 13th, 2010, 12:17 AM   #16
92ponylx's Avatar
92 Lx
Slow
guys i need to know if the bearing could just be messed up and the clutch still be good
Old September 13th, 2010, 08:58 PM   #17
92ponylx's Avatar
92 Lx
Slow
anyone....
Old September 20th, 2010, 03:41 AM   #18
bustang's Avatar
88 LX hatch
Yes. The bearing is seperate from the clutch itself. But once the bearing goes bad...you'll be stuck.
A-Rod
Threads Similar to: grinding noise in trans?
grinding noise? number1gt 99-04 7 August 19th, 2010 06:40 PM
grinding noise??? WonfastGT 99-04 5 March 15th, 2010 07:45 PM
Grinding noise??? WonfastGT 99-04 2 March 14th, 2010 01:45 AM
grinding noise need help nba1341 Classic Mustangs 12 March 13th, 2008 02:15 AM
Grinding noise I_eat_rice 99-04 2 February 3rd, 2008 01:02 PM
