Traction issue
Old April 1st, 2007, 11:23 PM   #1
sb2f5marine69's Avatar
sb2f5marine69 is on a distinguished road
Traction issue
Went to the strip today and ran a 14.3 with a 107.63 mph trap speed, but I spin through the 60 ft and it was a 2.84. The car just wont hook ive got bbk subframes and moroso drag springs, 90/10 front struts and 50/50 rear shocks the lake wood traction action bars suck so i took them off tonight. The car is capable of low 12's high elevens. I dynoed at 319 horse and 331 ftlbs of torque, it is a 5 speed car with 3:73 rear end. Any help would be great and would like to know what everyone runnin these times have suspension wise Thanks.........
Old April 1st, 2007, 11:57 PM   #2
95wip is on a distinguished road
Send a message via AIM to 95wip
what kinda tires are you running?
95' GT is being reconstructed!
Old April 2nd, 2007, 12:19 AM   #3
angermgt's Avatar
angermgt is on a distinguished road
have 89 gt and last season ran best of 12.6 at 119 with 365 rwhp. 60 ft. time was 1.97 with hardly any spin but with a launch rpm of 3000 rpm. i have upr uppers and lowers kyb agx adjustable shocks in rear and struts in front. struts are set at 2 out of 4 and shocks are set at 4 out of 6. tires are bfg drag radials 255 50 16s. hopefully some input you could use.
Old April 2nd, 2007, 12:20 AM   #4
Stangzilla's Avatar
Stangzilla is on a distinguished road
Yeah you seem to have an ok suspension but if it is on street tires it aint worth shit.. Get some slicks... What size and type of tire are you running?
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old April 2nd, 2007, 07:34 AM   #5
245.55.16 nittto extremes
Old April 2nd, 2007, 09:16 AM   #6
5-0stank is on a distinguished road
get some mickey thompson et street slicks.
1995 GT::Sold!
Looking for another stang...
Old April 2nd, 2007, 09:35 AM   #7
1990 GT Convert
ken5_0 is on a distinguished road
What air pressure (tires) are you running at the track? Play around with that a little.
Old April 2nd, 2007, 09:57 AM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Throw those tire in the garbage and put some slicks on it. 26x8.5-15 will be plenty at that power level. At that mile an hour you are looking at 12.40s or so.
Old April 2nd, 2007, 10:37 AM   #9
FIVE-0's Avatar
FIVE-0 is on a distinguished road
Send a message via AIM to FIVE-0
If your gunna be keepin those tires for a little bit, try and dog it out of the whole a little, it should help it not spin so much, but you'll still have a a slow 60ft cause of the slow roll
Old April 2nd, 2007, 10:41 AM   #10
FastBack71 is on a distinguished road
UR RUNNING 245??? get those things OFF get some slcks like darrel says!
My friends used to wonder Why i joined the air force. Now they wonder why they didn't.
Old April 2nd, 2007, 11:13 AM   #11
thanks, Hey Darrel what do u think about urp control arms? Ive also seen steeda weighted drag lowers and was thinking about those. I just dont want to burn myself again like i did with those lakewood traction action bars.
Old April 2nd, 2007, 11:39 AM   #12
mustangman9550 is on a distinguished road
If you don't wanna go slicks and risk an axle( the only reason I won't run em) then go up a few sizes in tire. I believe you should be able to go up to around a 275/40 which I run out back on a 17, but that's a SN95 not a fox body. I would think atleast a 265 in a 16 would hook alot better than a 245..........
Old April 2nd, 2007, 01:15 PM   #13
5literJeff is on a distinguished road
Send a message via AIM to 5literJeff Send a message via Yahoo to 5literJeff
So lemme get this straight, you were running a passenger performance radial tire with directional tread and getting 2.80 60 foots and from that you inferred that the lakewood traction action bars
. Wow.
Old April 2nd, 2007, 02:14 PM   #14
. Wow.
...my thoughts as well.
1995 GT::Sold!
Old April 2nd, 2007, 05:18 PM   #15
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
UPR makes some good stuff.
Old April 2nd, 2007, 05:20 PM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You either have traction or you don't. Traction breaks stock parts no matter what tire you have on it. Axles don't break because they have a set of slicks attached to them. They break because they are abused. You can break axles with street tires.
Old April 2nd, 2007, 06:33 PM   #17
El Conquistador
whiteboycustom's Avatar
83 coupe
whiteboycustom is just really nicewhiteboycustom is just really nicewhiteboycustom is just really nicewhiteboycustom is just really nice
Send a message via AIM to whiteboycustom Send a message via Yahoo to whiteboycustom
he lakewood action traction bars have 3 settings, which hole are u using, i have the same bars but have yet to install them, i am starting off at the lowest hole for the most hook up and work from there
Old April 2nd, 2007, 07:30 PM   #18
Stangzilla's Avatar
I have 275\40\17 on the back of my Fox and I used to have drag radials that size on there. There is no difference. Drag radials are usless on a 17 inch wheel.. There is no give in the sidewall wether you are running street tires or drag radials.. The only way you are gonna get great performance out of drag radials is get 15 inch rims and put drag radials on them. They have lots of forgiving sidewall cushion... Other than that slicks is the way to do and I recommend a 15 inch tire also. I am runnin the Hoosier 26x9x15 with tubes.. A little trick when mounting slicks with tubes.. Rub the tubes down with baby powder so when the tire slips on the rim it wont twist your tube with it.. And yes slicks do spin on the rim sometimes unless you have the tires screwed to the rim...
Old April 3rd, 2007, 01:13 AM   #19
Hey darrel couldnt find that tire size anywhere. Checked mt website and all they had were 26x10.50x15 will i have to roll my fender to clear that? Thats the narrowist tire i found.
Old April 3rd, 2007, 01:15 AM   #20
Stangzilla's Avatar
I run Hoosier 26x9x15. There awesome..
Threads Similar to: Traction issue
01' cobra traction control issue windsor351 99-04 7 October 3rd, 2007 07:37 PM
here is my issue bigbadwollfff04 Drag 35 July 5th, 2007 09:34 PM
t5 issue 342stroker 5.0 Mustangs 3 June 4th, 2007 09:41 PM
Brake Light and Traction Control issue ? wgmarq V6 Mustangs 2 August 10th, 2006 08:54 PM
