Brakes
Old September 13th, 2010, 09:11 PM   #1
1989 Mustang GT
SlaXX is on a distinguished road
Brakes
hey, i just replaced my brake pads.. pushed pistons back in.. were giving me a little trouble but got them flat, but my pads are rubbing and smelling like burnt rubber and metal and heating up REAL bad... so it's like they're constantly braking.. whats up do you think?
Old September 13th, 2010, 10:02 PM   #2
91cobra5.0's Avatar
98 Cobra
Bleed ur brakes
Old September 13th, 2010, 10:35 PM   #3
1989 Mustang GT
u sure bro? does that like take the pistons pressure off or something?
Old September 13th, 2010, 11:23 PM   #4
nolife's Avatar
91GT, 88GT, 02GT
Jack up the car and try to spin the wheel. I can't tell by your comment but was the piston always straight and not pitched at an angle while you were trying to get it in? Did you have the master cylinder cap off when you were doing this? I've never seen front pads hang unless the pistons were screwed up or something jacked with the way the pads were in. Did you have a hard time getting the calipers back on?
Old September 14th, 2010, 10:15 AM   #5
1989 Mustang GT
yeah i had a little trouble getting one back on.. and i dont think the pistons were messed up.. i had to struggle a little with a C clamp but it still went in as far as i could tell all the way.. and yeah when i jack up either side and spin the wheel it rubs..
Old September 14th, 2010, 03:07 PM   #6
'88 Mustang GT
DigitalDC89 is on a distinguished road
Send a message via AIM to DigitalDC89
sounds like you didnt take the cap off of the master cylinder, so when you pressed the piston back in, it somewhat pressurized the system a little bit. i could be way off here though.
'02 Mustang GTm Convertible - N/A Cammed Daily
'88 Mustang GTm - 1/4 Mile Build - 750rwhp Project
'97 Saturn SL2m - Ex-Nitrous Build - Back-Up Daily
Old September 14th, 2010, 05:57 PM   #7
1989 Mustang GT
oh man that's probably it. damn. how would i go about fixing that now? redoing them but with the master cylinder off?
Old September 14th, 2010, 06:17 PM   #8
'88 Mustang GT
i would just pop the cap off slowly and listen for any pressure. be sure to have a rag at the ready, because some fluid is probably going to overflow out of it.
if that doesnt fix the problem completely. then i would take the calipers off again, push the piston into the bore again, and reinstall them. with the cap off of course.
Old September 14th, 2010, 06:47 PM   #9
1989 Mustang GT
i know i'm sounding like a noob on this one but where is my master cylinder and how do i take the cap off.. i dont touch brakes usually
Old September 14th, 2010, 07:08 PM   #10
'88 Mustang GT
under the hood, drivers side back near the firewall. its yellowish-white, with a black cap on it. just twist it off.
Old September 14th, 2010, 07:29 PM   #11
1989 Mustang GT
well i took the cap off but didnt see or hear pressure.. should i be hittin the pedal or turn car on>?
Old September 15th, 2010, 02:30 PM   #12
'88 Mustang GT
its worth a shot i guess. i would just redo the calipers with the cap off now. hopefully that does it for you.
Old September 15th, 2010, 11:53 PM   #13
1989 Mustang GT
thanks bro if not maybe new calipers. whiiiiiich sucks.
Old September 16th, 2010, 12:10 AM   #14
ironsteed5.0's Avatar
91' 5.0 LX
ironsteed5.0 is on a distinguished road
Disengage the E brake!!!! lol
Threads Similar to: Brakes
Bad brakes symptoms but not brakes Stangin94GT 5.0 Mustangs 14 August 25th, 2010 02:58 PM
86 Brakes HOLLYWD69 5.0 Mustangs 2 January 31st, 2010 11:44 AM
Brakes Mickey 2005 - 2010 32 August 5th, 2009 03:21 PM
brakes Jucostud 2005 - 2010 15 July 11th, 2009 01:57 PM
cobra brakes vs Baer brakes 03SuperchargedGT 99-04 20 May 1st, 2009 05:08 PM
