Horsepower on a budget - Page 3
Old September 30th, 2010, 11:41 AM   #41
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by BlueberryStang View Post
Ok I was wondering what are some inexpensive ways to gain some HP?? I've already done headers, exhaust, a nice tune-up, and a BBK cold air intake. I'm 16 and I'm trying to find a job so at the moment I don't have much money. For now I have around $400 to spend, any ideas??
Gears.
Ok thank you. I'm deffinetly doing 4.10's.
On a different note, would it be a bad idea to do a cam swap on it with the stock heads??
Originally Posted by ReverendDexter View Post
That's what I hear. Cam swap on stock heads usually loses a little bit of power.
A cam swap won't necessarily lose power any where with stock heads but it has to be the right cam. Cam selection is a bit pickier with poor flowing heads. With heads that flow well, its possible for a shit cam to be used and still make ok power just because the heads are going to move a bunch more air than the poor flowing heads.
Old September 30th, 2010, 01:56 PM   #42
BlueberryStang's Avatar
1990 Mustang GT
BlueberryStang is on a distinguished road
Originally Posted by Digsj7 View Post
It's a zinc coating they dip the parts in. Almost like chrome. It helps prevent rust and corrosion.
Thanks I think I'm gonna get them.
1990 GT hatchback - BBK cold air intake, shorty stainless headers, FRPP 4.10 gears, MSD ignition, underdrive pulleys, 2.5 inch exhaust with o/r h-pipe into Flowmaster super 10series.
Old September 30th, 2010, 02:02 PM   #43
1992 Lx
11.39@119.24
Originally Posted by FastStang91Lx View Post
I would do a MSD coil for 40 bucks.
Power and Amp Underdrive pulleys.
Electric Fan (Tauras fan is cheap, but will require an alternator upgrade)
The aforementioned gears.
rotfl
Old September 30th, 2010, 07:54 PM   #44
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Most zinc coating is kinda yellowish, isn't it? All my zinc coated nitrous fittings are, and other zinc coated stuff I've seen.
Originally Posted by 93hatch View Post
rotfl
With underdrive pullies, even the power and amp series, it will require it. You can come and see yourself.... Fucker! And if you wait a couple months, you could see Snow....
Old September 30th, 2010, 08:06 PM   #45
1992 Lx
11.39@119.24
Tell that to my last fox with stock alt ud pulleys and taurus fan and my current one with the same shit
Old September 30th, 2010, 08:40 PM   #46
1991 Mustang LX 5.0
What about coming to my house and making snow angels with me??? You didn't answer that part.
Old September 30th, 2010, 10:32 PM   #47
sk1nner's Avatar
93 lx 5.0
sk1nner is on a distinguished road
zinc is a rust preventative coating. when you get bolts from the hardware store and they have that yellow coating that is zinc with yellow dichromate. its good shit. plating is not done by "dipping" the parts, theres ALOT more that goes into it than that. (8 years plating experiance, mostly aerospace shit)
Old September 30th, 2010, 10:49 PM   #48
1992 Lx
11.39@119.24
Only if you keep me warm
Old October 14th, 2010, 10:24 PM   #49
1990 Mustang GT
This doesn't really have anything to do with this thread but my power steering pulley shakes and swivels so I want your opinion on if you think it's the PS pump like the shaft or the pulley itself??
Old November 29th, 2010, 09:45 PM   #50
1990 Mustang GT
I need to know, can you take the valve covers off without taking off the intake??
Old November 29th, 2010, 09:48 PM   #51
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Remove valve cover bolts. Pull valve cover from head. No need to touch the intake.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old November 29th, 2010, 11:49 PM   #52
VM0824's Avatar
1989 Mustang GT
~14@99 (b4 turbo)
VM0824 is on a distinguished road
as long as it isnt blocking the valve covers. its only a space issue. if u can squeeze em out, then yes. if the intake is blockin em, no. is it easier with the intake off...probably.
give it a try first
306 w/ 8.9:1
ON3 70mm turbo kit - 9#'s boost
arp chromoly studs
47# FRPP - 255 walbro
3.73 - tremec 3550 - zoom hp kevlar clutch
msd 6a + blaster coil
lowered. sfc. HID
delete egr-smog-cats-a/c-foglights
battery reloc
QuarterHorse, BE, EA
Old November 30th, 2010, 12:17 AM   #53
moneymo's Avatar
1991 Mustang Gt 5.0
moneymo is on a distinguished road
Originally Posted by fs308 View Post
i got some 373s i'll sell cheap
Really? How much would you sell them for?
91 Mustang Gt
306/Under Drive Pulleys/gt40 heads/ so many more goodies
Old November 30th, 2010, 01:47 AM   #54
1990 ford mustang GT
bennyjet846 is on a distinguished road
it really depends where you're from blueberrystang. from where im at, cali, you can't get gears for 400 unless you're installing it yourself. i just bought gears at randy's ring and pinion website, costing me 219 bucks for some decent yukon ones. the masterkit(highly suggested) runs for around 125 bucks and don't forget the LSD and 80w90 fluid. that'll run you about 400 bucks and this isn't including install. however i seen some cheaper 4.10's which runs about 119.. but the sales rep he doesn't recommend them because they're noisy as hell because of the gear cut. with 400 bucks, u can do the gt40 intakes, i've seen some on ebay going for 75 bucks for used ones. But like what reverenddexter says, you dont want to do things over. you should start with heads. if you're looking to do work yourself u can get a nice set of trickflow heads for around 400-600 bucks and you would see a MUCH bigger difference in power than just a intake. that's my 2 cents.
Old November 30th, 2010, 01:55 AM   #55
1990 Mustang GT
I'm getting the 4.10's done for $450, and that's parts, labor, and all.
Threads Similar to: Horsepower on a budget
Help me build a budget 2v DSG40TH2V 99-04 11 March 4th, 2009 11:13 PM
tight budget daschaffa17 2005 - 2010 10 March 4th, 2009 02:58 PM
5.8 budget build help riggsracin 5.0 Mustangs 5 November 21st, 2008 08:57 PM
budget horsepower?? stangempire82 99-04 110 October 27th, 2008 12:31 AM
