subs where?
ok so im the type of person that likes a fast car but with a nice stereo system too.ive always had 2 twelves in my trunk but have or do any of u ever put the speakers anywhere else like under the seats or something crazy like that cause i dont like mines in the back.i want a system but cant think ok anyplace to put them besides the trunk and that's alot of weigth added too.
91 Mustang GT
1991 sliver GT
i have a buzuka tube. Its a 8". Sounds awesome. i have an external amp running it.
1991 Ford Mustang GT
Thats the price you pay for a good sound. Go with a buzuka tube or just down size your speakes and box. I have 10" in mine. i dont like all the room they take up either but im not giving up sound for space
89 GT
Without glasswork, you're not getting a sub anywhere else but the trunk. At least anywhere where you can make it sound good and use more than a 6" woofer.
1994 mustang gt
10.82 sec
mount a 15 inch in the spare tire area then cover it up and now one will know its there,being a 15 inch should give you plenty of base,i used to like a good stereo in my cars but im getting older and half the time i dont ever turn them on anymore,but if you run a 15 make sure you run a capacitor or it will suck to much power from the amp and cut out half the time
seans mustang
#7 | |
'69 Mustang Coupe
i've heard of people glassing 10's into the doors... but that is a shit ton of work and skill for it to sound right and i'd rather have a smaller trunk lol
I'm Blake. Above are the things I say
Just put a single 10" sub. or a single 12". Now your only using half the space. Are you looking to have nothing back there? What ever you do dont put it in the spare tire area. Ive seen people that do that and there subs dont last that long, they get smashed and ripped You cat put any thing on top of them so you still cant use you trunk. Plus you need a spare tire
#11 | |
SVTfocus, F250
build a slot port box for a 10" sub to put between the shock towers, to the specs of the sub you want, then bolt it to the floor and make a facia for it so it blends in completely with the rear seats and shock tower humps. i did that with a kicker cvr10 threw 300 watts at it and it will rock your shit. if you dont have a capable set of front components, that are amped, you wont hear anything but bass.
u dont have any pics mxnate116 that sounds good i just wanna have something decent sounding without all the weight of a box and all that other shit...cause i also put a battery in the trunk for the stereo alone.so that about maybe 100 extra pounds or more...
98 Cobra
I have 2 12s in mine and still have room for a 10lb bottle and the battery and I can still put some things in the trunk, I put the amp in the spare tire spot, the spare tire well is plenty of space for a 15in sub, get some mat and lay it out inside the well, spread some glass over it cut to fit some medium density fiberboard, seal the glass to the board, mount the amp on the back of the rear seats and run the wires under the carpet. a few friends of mine are using the round 15in kikers in their cars and those subs hit with a big enough amp.
SVTfocus, F250
ill try to dig something up, if you want a sub, you are going to have to have a box, unless you have a coupe you could run a different setup that doesnt require a box. there was a guy in the 5.0 mag that had the battery, amp and sub all inside one 'enclosure' that looked pretty clean. but it took up half the hatch area.
here is the best pic i could find of the old kicker setup. im going to be building a different setup for a different driver, but thats on hold until i can actually drive the car.
SVTfocus, F250
if physics were on your side then yes. but the mounting depth of the typical 15" driver is at least 8in. the depth of the spare tire well is 6. which means you need to glass in a 2" rise, at LEAST(a kicker cvr15 is 8 1/8"). also if the laws of physics were on your side (i.e. the spare tire well were square) you could get a MAX of 2.4ft^3 of airspace(which you wont). without doing the in depth calculations, your going to get a decent amount less airspace then that.
most 15" drivers need at least 1.8ft^3 of airspace. thats the minimum. and by minimum i mean real shallow bass notes. they cant follow through into the low end. it might add to the punchyness, IF and only IF you have a set of components that can produce decent midbass tones. other then that its just loud garbage. A single 10" sub in a well designed ported enclosure is what works best in these cars. i have tried out many different setups and a properly designed 10" system works the best.
MM's most Hated
2001 Mustang GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
um or u can just try buy a 10" solo baric x. No offense size means nothing. Anyone running 2 Cheap ass pioneer's or kicker cvrs and is complaining deserves to get hit.
Just got buy a high quality 10" or 12. Do the box right it wont be to much weight. Also make sure its hooked up to the proper size amp so ur reaching the subs potentional. Dont be like me and a 500 hooked up to 2 l7's. Its all abount the magnet so look into competition subs and ull save some space |
#17 | |
SVTfocus, F250
magnet size doesnt mean quality factor. there is tons of other factors that play into a good driver. also comp subs usually use more space, tuned higher, to get a higher spl. doesnt really play into a DD at all. and im sorry but a solo x is for nothing other then being loud as shit. the SQ is horrible on those drivers. doesnt matter if its l5 or l7. just a SPL sub. if you want sound quality look elsewhere
Last edited by mxnate116; September 16th, 2010 at 03:40 AM. Reason: there's alot more wrong here then i thought |
98 Cobra
here is mine and it knocks hard, i didnt have my bottle yet but everything is exactly the same except the subs are pushedall the way back and left and the bottle is to the right
98 Cobra
oh and i ran a 14.1 in pueblo colorado at a elevation of like 5400ft on my gt40 ecam set up before i noticed the lower intake manifold gasket was leaking coolant and it was running faster and faster with each pass and i was barely learning how to launch the nt05r's i had, cutting like 2.1 60s (driver error haha) with the speakers
#20 | |
1991 Mustang LX 5.0
That's what polyfill is for.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
Threads Similar to: subs where?
| Which Subs should I keep? | warrior86 | Audio/Video | 12 | August 19th, 2009 05:53 PM |
| Subs | Black01 | 99-04 | 17 | June 17th, 2009 07:14 PM |
| Subs | scxc15 | General Tech | 1 | March 1st, 2008 12:01 AM |
| Need Subs | discoernie | Audio/Video | 5 | August 9th, 2007 08:53 PM |
| SUBS? | theyanks904 | Audio/Video | 11 | July 16th, 2007 03:52 AM |
