95' Mustang 5.0 HO intake swap for 93 cobra intake...
Old April 2nd, 2007, 10:01 PM   #1
Look Ma! My First Post!
stang9587 is on a distinguished road
I have a 1995 Mustang Gt with a Cobra intake out of a 93'. I did buy the car like this but whats the procedure of swaping the 5.0 HO intake out and putting in the cobra intake? What are the adjustments I need to make? Would a 95 Gt even work with a cobra intake? Another thing is that the car keeps stalling out. I believe and im almost sure that its the air/fuel ratio. When I got the car I did have the fuel filter changed, new spark plugs, distributor cap and button replaced, adjusted the timing, and put in a new ignition module. I did hook up a scan tool and got 2 codes that the tps switch was bad and also got a code that the mass air flow sensor wasnt working properly. So I replaced the tps switch and soon ill be replacing the MAF. Now would if I install a new MAF and its still running rich and it stalls out? What should I look for next? Someone please help me out if they know anything..
Thanks, Joel
Old April 3rd, 2007, 06:20 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Buy an adapter elbow for it. Summit sells them.
Fix the codes and see if it still stalls.
Threads Similar to: 95' Mustang 5.0 HO intake swap for 93 cobra intake...
NPI to PI Intake Swap... Casper98GT 96-98 241 June 16th, 2011 05:35 PM
Aftermarket intake vs Cobra intake... Brent Russell 5.0 Mustangs 11 April 27th, 2008 11:35 PM
intake swap jst854 96-98 8 April 18th, 2007 10:15 PM
98 Mustang GT Intake Swap Help... Patterson98GT 96-98 22 April 18th, 2007 12:57 AM
Should I swap my stealth for a Vr. Jr intake 82GT 5.0 Mustangs 10 February 27th, 2007 09:51 PM
