EGR PLATE
Old April 2nd, 2007, 10:46 PM   #1
1997 Mustang Cobra
preston.rucker is on a distinguished road
EGR PLATE
What is the diff between 65mm 70mm and 75mm egr plates? Does it make a big diff by changing them?
Old April 2nd, 2007, 11:53 PM   #2
1990 GT Convert
ken5_0 is on a distinguished road
About 5 mm a step. :wink And yes a larger egr plate and K&N filter is worth about 175 HP at the wheels!!! Sorry man had to do it.
Old April 2nd, 2007, 11:57 PM   #3
stang fanatic's Avatar
stang fanatic is on a distinguished road
just remove your intake, block off the heat passage for your egr, plug your heater lines for the egr together, and hang your egr off on the firewall so it stays plugged in. then you wont need a egr plate.
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old March 24th, 2008, 04:03 AM   #4
Hunt_chevs's Avatar
2002 Gt
Not Slow
mine is fused to my intake manifold lol,.. anyone know how to separate them aside from pry bars etc. ...i tried that already
Old May 9th, 2009, 11:40 PM   #5
1993lxnotch's Avatar
1993 Mustang lx coupe
1993lxnotch is on a distinguished road
i used a flat head screw driver and a hammer and gently tapped it till it broke loose.....start a little on top the non side then repeat...worked for me. good luck
Old May 9th, 2009, 11:45 PM   #6
I Post Entirely Gay Too Much
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
So was mine. I did it the hard way but you might try soaking in a good penetrating solution overnight.
Old May 10th, 2009, 12:23 AM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The EGR plate size is directly related to the throttle body size. A bigger plate won't do anything for you without a bigger throttle body.
Old May 10th, 2009, 12:24 AM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
.....and effectively increase your air intake temperature....
Old May 10th, 2009, 02:50 AM   #9
Chris951's Avatar
1991 mustang 5.0
Chris951 is on a distinguished road
Thats what I did. I also used alot of pb blaster and it came off eventually
Old May 10th, 2009, 03:35 AM   #10
why the hell would you leave it plugged in if your deleting it?? just unplug it and the ecm disables it automatically for you
Threads Similar to: EGR PLATE
NX 2v Plate Kit TheBusher 99-04 24 September 8th, 2007 05:33 AM
PI adapter plate caintcatchmyGT 96-98 38 August 20th, 2007 04:36 PM
Thinking About A New Plate... ChrisJ The Clubhouse 52 March 31st, 2007 08:56 AM
IAC Restrictor Plate smokiebear911 99-04 2 March 26th, 2007 01:52 PM
[vin plate ] Gears does this O5 GT have? Convertible 5.0 2005 - 2010 6 March 19th, 2007 06:30 PM
