Engine ??
Old September 16th, 2010, 09:42 PM   #1
91Mustang GT's Avatar
1991 Mustang GT
Sloowwwww
91Mustang GT can only hope to improve
Engine ??
Okay, Let's start this off. My dad has a engine out of a 73 Ford Van (He thinks it's a 73) He put 4 valve release pistons in it it has a steel crank and forged rods. It has no cam, intake, or heads. Will the heads intake and cam from my stock 1991 mustang gt fit on this motor?
Black 'Stang Crew #1337
Old September 16th, 2010, 09:46 PM   #2
fogged306's Avatar
89 GT
If it's not a big block, yes. But you will need linkbar roller lifters.
Old September 16th, 2010, 09:51 PM   #3
1991 Mustang GT
Sloowwwww
Really?! I didn't think they would fit! Awesome! So everything will fit all I need are those roller lifters? How much are they.
Old September 16th, 2010, 09:54 PM   #4
FastStang91Lx's Avatar
1991 Mustang LX 5.0
400 bucks give or take. What is this motor that you speak of though? 351 or bigger?
Old September 16th, 2010, 09:59 PM   #5
1991 Mustang GT
Sloowwwww
Just a 302
Old September 16th, 2010, 09:59 PM   #6
1991 Mustang GT
Sloowwwww
No wait it's a 306
Old September 16th, 2010, 10:11 PM   #7
fogged306's Avatar
89 GT
Is there a reason you want to switch blocks?
Old September 16th, 2010, 10:12 PM   #8
1991 Mustang GT
Sloowwwww
The engine is brand new Mine has 178k miles on it
Old September 16th, 2010, 10:23 PM   #9
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
Are the pistons in the new motor forged?? Because your factory ones are. I also beleive the early model 302's were 28 oz balance, and your's is a 50 oz. If it were mine, I'd ring and bearing your orignal motor and it will be good for another 178,000!
I dought the van motor would have a steel crank, because I don't think 302's came factory with one(except for orignal BOSS 302)and a aftermarket steel crank is about $600. Really not worth it for a 73 Van.
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Old September 16th, 2010, 10:28 PM   #10
1991 Mustang GT
Sloowwwww
So should I just take the bottom end out of my Dads motor?
Old September 16th, 2010, 10:48 PM   #11
fogged306's Avatar
89 GT
Also, I'm an idiot for not seeing that you said intake.. with what you're doing will work, but if someone else reads this I don't want them to think that a 302 intake will work on a 351.
Old September 16th, 2010, 10:51 PM   #12
1991 Mustang GT
Sloowwwww
How much hp do you think it will have?
Old September 16th, 2010, 10:52 PM   #13
fogged306's Avatar
89 GT
Same as you have now... well that all depends on the compression of both, but it won't really be anything noticeable even if it is higher compression by a point or so. If you're rings aren't bad, keep running the engine you have now until it goes.
Threads Similar to: Engine ??
2005 V6 engine swap to 2002 saleen engine MCLARK V6 Mustangs 7 May 14th, 2010 06:02 PM
2005 V6 engine swap to 2002 saleen engine help? MCLARK 2005 - 2010 7 January 11th, 2010 09:27 AM
Engine install: Life engine up, or drop engine? trill gear head 2005 - 2010 14 October 26th, 2009 01:17 AM
Washed n cleaned engine today.. pics of engine bay. MustanG_guy17 The Clubhouse 40 January 4th, 2008 10:14 PM
1990 GT NO Engine Will 96 4.6 licolin town car engine FIT?? zygo4406 5.0 Mustangs 10 June 4th, 2007 05:53 AM
