Voltage problem
Old September 16th, 2010, 11:55 PM   #1
bigcurt444's Avatar
1993 Mustang GT
N/A
bigcurt444 is on a distinguished road
Voltage problem
Hey guys I have a bit of an electrical issue. When I turn my car to the on position everything in the car works as far as electrical components go. Once I start the car the A/C stops working so does my turn signal and dome light. I found that if i turn my ignition back just a little before cutting it off the A/C starts working again but my turn signals dont and neither does my dome light. Also tonight when I was driving my voltage meter went up between 16 and 18 volts then when I stopped to idle it went back to normal except when I slowed down the battery light popped on for a split second then went off. The only thing I have done recently is change both battery cables because the old ones were corroded. Let me know if you can help. I appreciate it.
Old September 17th, 2010, 12:04 AM   #2
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
Sounds like you need an ignition switch
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Old September 17th, 2010, 12:14 AM   #3
bigcurt444's Avatar
1993 Mustang GT
N/A
yeah I thought so too. What about for the sudden jump in voltage?
Old September 17th, 2010, 08:38 AM   #4
95tbirdv8's Avatar
1990 mustang gt
I would change the switch since there cheap and go from there
Old September 17th, 2010, 09:00 AM   #5
fogged306's Avatar
89 GT
Put a multi-meter on there and see what's really going on. It could be that you have a loose connection on one of the new cables, or your regulator is on it's way out. First problem definitely sounds like the switch.
Threads Similar to: Voltage problem
Charging / voltage problem.. chrisificti0n V6 Mustangs 13 April 14th, 2011 03:08 AM
2001 mustang GT voltage problem cbjohnson9 99-04 9 September 4th, 2010 05:23 PM
Low voltage problem/issue Gunsbee 5.0 Mustangs 2 May 30th, 2010 09:04 PM
Voltage Problem stang300a V6 Mustangs 22 November 9th, 2007 02:44 PM
voltage problem with my 91 stang mysweetstang 5.0 Mustangs 8 August 16th, 2006 01:03 PM
