TMASS are you still around???
Old September 17th, 2010, 06:41 AM   #1
e3sean's Avatar
1988 lx
9.68@142
i need some of your expertiese.
here is your drawing
here is after i hacked it up i assume this work??
<font size=4><b>MILITARY CREW
Old September 17th, 2010, 07:05 AM   #2
91 mustang gt/90 7up vert
fordguy1280 is on a distinguished road
no, that's not going to work. you still have to have power going to the switch to power the motors. as you have it right now, you looped the hot on both switches together, with no feed. also you need to have some form of a fused power input to the motors in case of a short so you don't catch the wiring on fire. The grounds on the other hand can be tied in together but it would be a waste of wire. just ground them inside the door frame in the chassis.
just wondering, what are you trying to do?
Old September 17th, 2010, 09:35 AM   #3
nolife's Avatar
91GT, 88GT, 02GT
No it won't work. You are missing +12v to the switches in the drivers door. As it sits, only your passenger switch will work.
Effectively, the only difference between your setup and the factory one is one wire which is the small horizontal pink line between the two pink runs (circled in red below). Tie the pink colored line in the drivers door to the other pink line or run it to its own fused source and it should all work. Remember when tracing this out, those switches aren't ganged together.
EDIT: I just reread the post above mine and it seems he said the same thing, sorry.
Old September 17th, 2010, 10:00 AM   #4
Whos tmass?
PeteAndersonRacing.com
Old September 17th, 2010, 10:46 AM   #5
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Tmoss's brother, dur.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old September 17th, 2010, 11:09 AM   #6
1992 Lx
11.39@119.24
Originally Posted by 93mustank View Post
Whos tmass?
bill cosbys son
Old September 17th, 2010, 11:26 AM   #7
e3sean's Avatar
1988 lx
9.68@142
my bad this is what i ment to do, yes there would be a fuse it would be hooked up to my other accessories on the switch. my bad it was early i ment TMOSS!
Old September 17th, 2010, 12:22 PM   #8
tmoss's Avatar
tmoss is on a distinguished road
the one above looks like it will work.
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
Old September 17th, 2010, 04:02 PM   #9
e3sean's Avatar
1988 lx
9.68@142
Thank You Sir.
