Common oil and Coolant problems?
Old September 18th, 2010, 06:41 PM   #1
RhadCundell's Avatar
RhadCundell is on a distinguished road
Send a message via AIM to RhadCundell
by the firewall their was a bunch of coolant.. Anywhere that could be coming from? Also the oil is leaking from the center of the car. Its dripping somewhere but it looks like its been dripping for awhille now so its hard to see where it is dripping from. Any common places to look?
Old September 18th, 2010, 06:43 PM   #2
blaten22's Avatar
89 LX
blaten22 has a spectacular aura aboutblaten22 has a spectacular aura about
Send a message via Yahoo to blaten22
firewall leak sounds like a heater core. Oil could be anything on the back of the motor. Wash it and add oil leak detector and find a cheap uv light. Works wonders.
Old September 18th, 2010, 06:45 PM   #3
All right ill give it a try. Its just an annoying problem. The oil level isnt going down what so ever tho.. but its for sure oil i just got the car the oil isnt fresh so im kind of lost.
Old September 18th, 2010, 08:15 PM   #4
blaten22's Avatar
89 LX
If it isn't fresh it maybe fixed and just not cleaned. Try this. clean the bay and under side, then take a cardboard box and cut it flat. Leave it under the car a few days everyday and seee if it leaks. It will give you a round about location of where to look as far as the front of back side of the motor. After that add the oil dye stuff and a cheap uv light. Also check tranny lines for any small leak or even the tranny itself. Fluid can go any where when your driving.
Old September 18th, 2010, 08:42 PM   #5
thats why its hard to pin point, because its coming off the exhaust like right before the cat
Old September 18th, 2010, 09:18 PM   #6
FastStang91Lx's Avatar
1991 Mustang LX 5.0
I vote rear main seal. But as previous person stated, you need to wash everything really so you are 'starting fresh' and go from there. I have access to a hoist and hot water pressure washer so it's easier for me, but I would assume that if you can get your car as high up as you can on jack stands and wear a raincoat or something, you should be able to get under there good enough with a standard pressure washer and plenty of degreaser.
The rear main seals on our cars can leak if you look at them wrong, so that's my bet, but you would also want to check your transmission tail shaft for leaking as well. While your car is up in the air, you can check the torque on your oil pan bolts, as well as your transmission pan bolts if it's an automatic. If you go through the process of cleaning this all up, I would just throw the dye in right away and check it daily. Also, come to think of it, if your intake is leaking on the back side seal, it will run down the back of the motor appearing to be a rear main seal leak too. Keep that in mind.
Old September 18th, 2010, 09:23 PM   #7
1988 Mustang 5.0 LX
12.48@118.27
ddarkslayer is on a distinguished road
I say rear mail seal and heater core. Done
Old September 18th, 2010, 09:28 PM   #8
aka Nature boy
sickfox's Avatar
blk 89/red 91 XJ Limited
I like turtles
sickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant future
hook line sinker. done.
Black Stang Crew Founder #-1
MM+Cleavage Club #15
www.xjor.org
I would drag my dick through a mile of broken glass just to hear her fart through a walkie talkie
Threads Similar to: Common oil and Coolant problems?
Looking to buy 05-09 V6. What are some common problems/things to look for? mrsinister2424 2005 - 2010 V6 48 June 1st, 2010 02:33 PM
Common Problems Cadillac 96-98 10 July 10th, 2008 09:28 PM
03/04 Cobra common problems t-man2 4V / SVT 40 June 2nd, 2008 07:36 AM
Common Cobra Problems over 80k zact1024 4V / SVT 1 May 24th, 2008 02:13 AM
oil in my coolant kdawg48_2000 V6 Mustangs 2 August 6th, 2006 11:18 PM
