mpg
all of a sudden my car has been getting horrible milage. i went threw a half a tank in two days. whay has it gotten so bad.
could be a number of things. i think the easiest would be to check o2 sensors, could be causing a rich condition. did your check engine light come on ? does the light work ?
my check engine light came on all of the sudden but it only comes on like every 10 seconds it kind of like flashes but not all of the time
how do you know if the o2 sensors are bad?
if your check engine light is on, and seems to flash randomy. it is flashing a code. so you need to retrieve that code..could be the problem
how do i go about retrieving the code?
1988 Mustang LX Turbo
it could be running a little rich and or the fuel lines problably leaking, or maybe the knock sensor is bad
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
