Temp Gauge Help
Ok heres my question, does anyone know of another loction to install the sensor for my aftermarket temp gauge OTHER THAN where my stock one is right now? I bought a triple gauge set becuase everyone tells me how mine arent accurate at all and I'd like to keep the stock ones working becuase it just wouldnt look right if they didnt. I figured out the volts and oil pressure gauges and this one has me stumped, maybe I'm just looking too hard. Any ideas?
what kind of temp gauge? I could help futher.
Or splice into the one already hooked up.
American Muscle Against Ricers. Member #6920. |
My bad what kind as in oil, water, exhaust, or etc?
Well like he said why dont you just tap into the wires for the stock location? Just a second thought I have seen over the years that SunPro is not known fo their accuracy.. Maybe they have gotten better I dont know..
Its not an electrical gauge, or I would just tap into the wire. I was just wondering if anyone knew of another location on the engine that I could take say a bolt out and screw the sensor for the new gauge in. So far not looking so good.
Here is the installation guide for my gauge, the picture is of the sensor. Hopefully that will help you guys to see what Im talking about.
http://www.sunpro.com/publish/2004/0...lish_16300.pdf |
#10 | |
look for a plug in a water jacket on the cylinder head somewhere around the exhaust
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
I do fall under the computer controlled section, which when read further states that I cannot use the spot that the stock sensor is in, as the computer uses it for engine management purposes. My sensor IS NOT electrical. The only electical connection on it is for the lighting. It has a copper sensor on one end which connects to the gauge through a roughly 6 ft thin copper lead. No fluid or air runs through this as it is sealed on both ends. Im telling you it is a mechanical gauge, I know how to install it. All I was asking was if anyone has any info on where an additional "tap" into the flow of coolant would be on the engine so I can install it and keep the computer controlled one in place.
#13 | |
ok, I went and looked. The only thing i see to do is remove the sending unit for the GAUGE and install your line there
Do you know if that is the one that goes to the computer or is that just for the gauge? If its just for the gauge I'll put it there but if its what the instructions were talking about then I cant use that one.
There is only one temp sensor on the stock system and it is the temp sensor that sends the signal to the computer... So you cant use that one.. Y dont you just get rid of that SunPro crap and get an electrical unit.. Other than that you are gonna prob have to drill and tap another hole in your manifold if you dont have a plug in there already...
Where is that exactly?
I've put them in a radator, Removed the old one and put my new one in. I didn't know if you had exhaust one which is spliced into the o2 sensor, Oil temp which is put into a couple places itself. Of course drilling a hole in the radator is tricky.
Threads Similar to: Temp Gauge Help
| autometer temp. gauge | 5.0FUZ | 5.0 Mustangs | 12 | August 13th, 2007 01:04 PM |
| Temp gauge don't work? | alabamastanger | 5.0 Mustangs | 4 | July 20th, 2007 09:09 PM |
| new temp gauge | burnout5.0 | 94-95 | 3 | July 6th, 2007 04:10 AM |
| Engine Temp Gauge "OUT OF ORDER"? | sweet99 | 99-04 | 3 | March 21st, 2007 06:08 PM |
| High Temp | dcraig8 | 94-95 | 4 | January 23rd, 2007 12:39 PM |
