Rough Idle and Almost Dies After Warmed Up
Old April 4th, 2007, 03:15 PM   #1
Gallie's Avatar
Gallie is on a distinguished road
1991 5.0 all stock with 180,000 miles. I replaced the IAC and disconnected the battery to ensure a computer reset. It did not fix the problem, which is as follows:
- Cold starts are fine and holds a higher idle until warmer.
- When warm the idle lowers to around 800 rpm or so (normal) and idles very smooth. This will continue for some time 20 plus minutes or so.
- I'll be sitting at a light and suddenly something turns on, or off or some setting is implemented and the idle suddenly drops...the car runs very rough with a mis.
- It remains like this from this point on, until my next cold start up, etc.
I'm tired of driving with 2 feet to prevent stalling!!!
The IAC is the only part I've replaced and the Engine Light has been flashing for the past years, even when the car didn't do this.
Anyone else have the same problem and a solution? I will try the EGR valve next and then go from there, but any help would save me time and money.
Thanks,
Gallie
Old April 4th, 2007, 04:17 PM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
yea i was just gonna say EGR but thats hould really have no affect, maybe the wiring for the IAC is no good
Old April 4th, 2007, 06:13 PM   #3
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
SALIV8 is on a distinguished road
Chceck your codes, you really should fix whatever is settin the check engine light.
Old April 4th, 2007, 07:38 PM   #4
cobraetti's Avatar
2001 svt cobra
no way (IRS)
cobraetti is on a distinguished road
Mine did(i hope) do this in the past. I would definatly check for codes. I cleaned the ECT sensor and replaced the ACT (clogged with carbon). I geuss you could confirm the voltage at the TPS, I even found out that my T-stat was faulty trying to solve this problem. good luck keep us posted
Build #1249
MM New Edge Crew Member# 6
Old April 5th, 2007, 04:30 PM   #5
Darren E is on a distinguished road
Check your tps voltage when warm sensor could be getting hot and acting up. Also check your o2 sensors one could be shorting out causing it to go full rich at idle dumping too much fuel. Ok under throttle.
Old April 11th, 2007, 10:30 AM   #6
Gallie's Avatar
Thanks for all your comments. I'll try what you've recommended.
I replaced both O2 sensors a short time ago hoping it would fix the flashing engine light, but nope. So I'll assume they're OK for now.
What device do you recommend for checking the codes? Where do you buy it?
Thanks.
Old April 11th, 2007, 05:07 PM   #7
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
You can use a paper clip or buy a scanner from here.
http://www.midwayautosupply.com/pc-6...er-cp9015.aspx
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old April 11th, 2007, 09:23 PM   #8
1990 5.0 LX Notch
flamed 98 gt is on a distinguished road
Have the same problem with mine it was a vacume (sp) problem.
Old April 12th, 2007, 01:36 PM   #9
Dave is on a distinguished road
I had an 89GT that would run until it got hot and then shut down until it cooled off( like 2- to 30 minutes later.
If that describes it, Check your TFI Module. It is the grey thig on the side of your distributor with wires comming out of it. They are like 60 bux at the auto parts store, but the trick is getting a tool in there to get it off the distributor. Way back when, ford had a special slim tool to get ot off, I think it is a Torx head.
As soon as I replaced it, it ran fine again.
TFI = Thick Film Integrated
Like you had mentioned, if you keep the RPMs up the car will run, The Module has 2 rpm ranges Low and High.
If the High were to blow out the car would die at High revs, but if the low goes out it just dies until it is cool enough to run, because the module is overheating.
Hope that helps, I worked at a car dealer when I had the problem, and asked one of the techs, and he was like "It's the module" And it was.
Good Luck
Old April 12th, 2007, 07:49 PM   #10
cobraetti's Avatar
2001 svt cobra
no way (IRS)
how do you get that thing off?, anyone
Build #1249
Old April 12th, 2007, 08:27 PM   #11
Honestly, I had to mark the distributor, and then turn it so I could get at it. I believe there is a slim socket, that takes the bits for a normal spiner handle or drill, and you get right in there with that thing and it fits.
However it was much easier to put on because i changed the screws to phillips or something.. but then again I owned a hardware store so I had acess to alot of fasteners.
If you get in a hiuge bind, I will try to see if i can find a picture of the extremely tiny ratchet.
I just remembered i think I took it of with a Torx Bit and a pair of alligator vise grips, or needle nose pliers
Threads Similar to: Rough Idle and Almost Dies After Warmed Up
Rough Idle killagt46_t-top 99-04 5 April 20th, 2010 11:22 AM
rough idle :-\ help please! i know nothing about cars. tehdwarvenn 5.0 Mustangs 8 November 5th, 2007 10:01 PM
START IDLE, RUNS THEN DIES slownomo All Other Vehicles 6 October 6th, 2007 11:20 AM
rough idle, bog @ 3500 RPM Lmagee 5.0 Mustangs 11 September 19th, 2007 01:01 AM
Intermittent Rough Idle and Stall Gallie 5.0 Mustangs 16 September 5th, 2007 11:52 PM
