1988 5.0 Mustang Coupe
Hazard switch wiring
Hey all,
I was changing out the gauge cluster in my 1988 Mustang, but some of the wires for the defrost switch and the hazard switch pulled out of their holes. So now I'm not sure which wires go into which hole. Not having any luck with google. Does anyone have a wiring diagram for the hazard switch and the defrost switch? Thanks |
No one? I even got the defrost switch figured out. But I'm still at a loss with the hazard switch.
Even if someone could just take a picture of the back of the switch, so I can get an idea of what goes where. |
1991 Ford Mustang GT
Wiring diagram for hazard light switch? - Mustang Forums at StangNet or try this one
1992 mustang lx hazard switch wiring - Ford Mustang Forums
Thank you so much, that's exactly what I needed.
Threads Similar to: Hazard switch wiring
| wiring a kill switch | mell0 | 99-04 | 41 | January 26th, 2012 07:51 PM |
| Wiring for battery relocation/cut off switch | mounder27 | 99-04 | 9 | September 29th, 2010 12:55 PM |
| Lost wiring harness? Multifunction Switch? - Help | 1988stangGT5.0 | 5.0 Mustangs | 5 | July 11th, 2008 11:37 PM |
| trac off switch wiring help!! | workinprogress | 99-04 | 20 | January 19th, 2008 05:48 PM |
| Wiring window switch | Timber | 99-04 | 11 | March 22nd, 2007 07:26 PM |
