Throttle body
Old April 6th, 2007, 08:11 PM   #1
shurb125's Avatar
1993 Mustang LX Vert
shurb125 is on a distinguished road
Throttle body
Is Accufab a good brand? What do you guys recomend? 93 LX vert 5 speed
Old April 6th, 2007, 08:15 PM   #2
JBIGBOOTSY's Avatar
1990 LX hatch
What mods do you have? I think accufabs fine, But if your close to stock, it isn't gonna help out much.
Old April 6th, 2007, 10:00 PM   #3
Accufab is one of the best on the market. With that being said, I will have to agree with JBIGBOOTSY. You really need a bigger/better top end before you touch the tb before you will notice anything.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old April 6th, 2007, 10:11 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Like has already been mentioned, Accufab is one of the best if not the best out there but if you don't have anything more than some minor bolt ons you will hurt yourself by going to a bigger throttle body.
Old April 7th, 2007, 12:29 PM   #5
shurb125's Avatar
As of right now basicly bolt ons, BBK CAI, Underdrives, longtube headers, BBK H pipe, 70MM MAF, Steeda Subframe connecters, UPR upper and lower control arms, Koni adjustable rear shocks, flowmaster exhaust system. I'm in the process of saving for the Trick Flow Track Heat topend kit and probably go ahead and get the R series intake and the stage 2 cam. I have a set of Ford motorsport 24# injectors that I will install when I install the kit. I was just wondering what size would be sufficient, Summit said that the inlet on the intake would accept up to 75MM throttle body. What do you guys think about this arangement, and do I need to go larger than a 70mm MAF?
306 TFS heads stage 3 port & polished, TFS stage 2 cam, TFS Track heat intake, DSS pistons, 24# injectors, 76mm MAF, 70mm BBK/Edelbrock TB and spacer
Old April 7th, 2007, 07:03 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Once you get heads, cam and intake you could move up to a 70mm throttle body if you wanted. I wouldn't go any bigger. Get the biggest Mass Airflow sensor you can find.
Threads Similar to: Throttle body
Throttle Body Snipe061 V6 Mustangs 8 September 11th, 2007 04:28 PM
Throttle Body autoranch 96-98 4 August 7th, 2007 09:24 PM
bbk throttle body dumps 2005 - 2010 4 March 26th, 2007 08:02 PM
new throttle body? AFtriathlete General Tech 18 March 20th, 2007 01:14 AM
throttle body noppe180 96-98 2 November 4th, 2006 06:57 AM
